How to Make Your Own Sprinkles at Home
6,211
119
7
Posted
Introduction: How to Make Your Own Sprinkles at Home
After learning how easy it is to Tint Your Own Custom-Colored Sprinkles, I was really excited to learn that it is also easy to make your own sprinkles from scratch at home. Not only is this a fun do-it-yourself kitchen project, but it’s a great way to save a trip to the store when you don’t have sprinkles on hand!
Step 1: Supplies Needed to Make Sprinkles at Home
To make sprinkles at home, you will need:
Step 2: How to Turn Royal Icing Into Homemade Sprinkles
Add water to your icing (a tiny bit at a time) until your icing reaches a 30-count consistency. To test the consistency of your icing, slice a knife into the surface of the icing and count how long it takes the icing to fill back in and create a smooth surface. For 30-count consistency icing, you should be able to count “one one-thousand, two one-thousand, three one-thousand…” to 30. For more information about how to use the different consistencies of royal icing, see the How To Make Royal Icing section of 101 Essential Cookie Decorating Resources.
Separate the icing into smaller bowls, one bowl for each color of sprinkles you are making. Tint the icing with gel food coloring and load each color into a piping bag with a small tip.
Use your royal icing to draw lines on wax paper. If you want to separate your sprinkles by color, draw only lines of the same color next to each other. The lines should run parallel to each other and can be as long as you like. Set the royal icing lines aside to dry completely.
Step 3:
Peel the wax paper away from the icing and stack the royal icing lines together. Using a sharp nice, hack away at the icing until you have a pretty pile of sprinkles. Your homemade sprinkles will resemble jimmies, except the edges will be straight instead of rounded.
For more creative sweets made simple, visit sugarkissed.net or stay connected on FacebookTwitter, or Pinterest.
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Pocket-Sized Contest
    2 Comments
    Awesome! I really need to make these! Do you know how long they last?
    Penolopy, my royal icing recipe uses meringue powder instead of egg whites. If you use that to make the sprinkles (or any other icing decorations), they should last forever. You can find my recipe here: http://sugarkissed.net/royal-icing-recipe/
