How to Make a $50 Pottery Wheel
70,649
682
48
Posted
Introduction: How to Make a $50 Pottery Wheel
You can use a ceiling fan motor and a plastic bucket to make a pretty decent pottery wheel for under $50.  The most expensive part is the ceiling fan, and you can pick those up, on sale, for $30, or at a garage sale for even less.
History:  My kids were both into pottery, and really wanted a wheel.  Decent wheels are pretty expensive, but luckily a friend of mine had a Clay Boss pottery wheel, and loaned it to us for a few weeks.  We had a lot of fun with it, but alas, had to give it back.  I recently picked up an old ceiling fan that one of my neighbors was throwing away, and I realized I could use the motor to make a pottery wheel, similar to the Clay Boss.  Here is a link to my original inspiration:
http://www.clay-king.com/pottery_wheels/speedball_pottery_wheels/speedball_clay_boss_pottery_wheel.html
3 People Made This Project!
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
41 Comments
I love the work and thought you put in this! ~ So, don't take this as a knock on your project-Because I am going to make a few mods and give this project a go, thanks to your inspiration!! But, I question just how safe this wheel is. And being that your kids use this, you need to know there will be a fair amount of very WET clay slip that will make its way under the wheel head and on the motor. The motor will need to be sealed somehow from the wheel head. Electrocution is not cute, lol! And I would be concerned about a finger or clothes getting hung up under the wheel head. You got my "wheels spinning" none the less!
Hi. Thank you for your kind wording and constructive criticism. I actually did consider the proximity of water and electricity in this build. Although it may seem unprotected, the motor is covered by a "spinning umbrella". When stopped, you can pour a glass of water on the wheel and not get the motor wet, because it drips off the umbrella, and down the sides. When the wheel is spinning, the protection is even better, because the water is flung out (centrifuged) against the sides of the bucket, where it harmlessly drips down. After some use with water and slip, my motor is bone dry.
Also, ceiling fans use induction motors, which are safer around water than standard motors, because they have no commutator and brushes that segment the electrical wiring. That is, induction motors have one continuous wire, through the entire motor, so the electricity always has a good path to ground. If you look closely, inside the back end of a running hair dryer, in a dark room, you will see that it occasionally generates tiny sparks, inside the motor. This is where electrical contact is being made and broken, hundreds of times per second. You will never see these sparks inside induction motors. Incidentally, this is also why induction motors are so quiet.
I will make two safety recommendations: 1 - Plug this wheel into a GFI outlet, such as in a kitchen or bathroom or basement for extra precaution. 2 - Drill a hole in the side of the bucket, 3 inches from the bottom, to provide an overflow, should the bucket ever start to fill up with water. This is unlikely, because it would take almost a gallon to get 3 inches in the bucket, and water should evaporate between uses.
I never considered fingers getting caught. I suppose that could happen with any pottery wheel, as they all have splash shields. In the video, my wheel was a little off center, after I mounted it. I fixed this by drawing a pencil line, at the very edge, while it was running, and then trimming to that line, with a saw. This consistent edge should reduce the risk of caught fingers, because there is nothing to "grab" you. You might also want to sand and round off the edges of the wheel, so they are even less likely to catch anything.
Quick question:
What power specifications does the motor u used has?
Thanks in advance!
cheers Massimo
Great idea, thank you for sharing.
Is there any instructable on how I would go about attaching a sewing machine pedal plus a variac (variable controller) to control the speed? I know nothing about electrics, so I don't even know the right words to search, and I want to make sure that I'm doing the right thing! Anyone know?
Actually, all you need is an on/off foot switch, and those are really easy to use. You just plug them into the outlet and plug your wheel into the switch. Look for a "momentary" or "deadman" foot switch. They cost about $20, and are typically used with power tools such as wood routers. Here is one I just found on Amazon.
http://amzn.com/B000LJNJOE
This wheel runs at a good speed, if your hands are on the clay, but too fast, if not. Simply press on the pedal, when you are working, and let off otherwise.
Is there any way to control the speed of the wheel? Great instructable! :)
Thanks. A sewing machine pedal will work. Just a plain on/off pedal switch can work too. You want it full on when you are working the clay and slower or off when you are not.
i am 12 years old and i am going to make this tomorrow and it looks like it works we will see tomorrow #loveit
