3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Make a Boomerang
Make an amazing boomerang that works great. Very easy to make and extremely fun to use. For outdoor use only. Test results included at the end.
Step 1Materials needed
Materials needed
Begin by getting two paint sticks or two pieces of flat wood. Wooden rulers will do. but you will have to add groves.
65 comments
1-40 of 65next »
Feb 5, 2012. 12:38 AMarcanetreaure says:
can i use Popsicle sticks? than to a wooden ruler
Feb 14, 2011. 9:36 PMgeodez says:
I saw this video on Youtube before I searched it on Instructables, now I'm going to Lowes to get some paint sticks as soon as I can.
Jan 21, 2011. 9:21 PMjessicatompson says:
check out this guide too. It really good. i get them returning to me from this how to throw a boomerang guide
Sep 21, 2007. 11:18 PMBoomGuy says:
No matter how many times I told people how to throw boomerangs a lot would still throw them the wrong way. Till I started to tell them to throw it like a knife or tomahawk. Spin is very important. Generally the more spin you put on it the better. You also want the top side facing towards you. You want the wind to blow on the cheek on the opposite side of your throwing arm. Adjusting your angle to wind will adjust the return point of the bomerang.
Nov 20, 2007. 11:28 AMaquaman33 says:
how do you know so much bout boomerangs
Jul 21, 2010. 9:35 PMTren509 says:
Well, in the olden times, the ancestors spoke of a heroic, boomerang-savvy instructabler. At the time, it made absolutely no sense. But now it all makes sense.
May 8, 2010. 10:15 AMpannekaker says:
Probabely the best angle to throw a boomerang is at 45 degrees to the right of the wind direction and try to put as much spin on it as possible as BoomGuy said :)
Mar 28, 2009. 12:21 AMlimhanxian says:
When i was kid after thrw it i run coz scare to catch it XD
Mar 20, 2010. 1:32 PMFFVIIBOY says:
Same here but with baseballs :D Actually yesterday i wuz using this boomerang and it came back and it wuz heading toward my face so i started to run but then it hit me in the neck wen i turned around...... wow im pathetic.... Then 5 minutes later it got stuck in a tree and its still there. ive been trying to get it out with my bow and arrow
Aug 24, 2007. 8:55 AMcj360 says:
i need help.why isnt it coming back is this why cause i am using wooden rulers. help?
Sep 5, 2008. 3:44 PMgamerguy314 says:
it might be because the rulers are too heavy, and if you didn't round the corners it won't have correct aerodynamics. If they are too heavy, gravity pulls down on the object before it can come back to the thrower.
Mar 17, 2010. 3:09 PMFFVIIBOY says:
actually i used 2 rulers i found and they worked fine when i threw it right
Aug 6, 2008. 7:43 PMyeerk21 says:
Aboriginal boomerangs have been thrown around for at least 10,000 years, and constitute a quintessential Australian icon. Many boomerangs, and also the near-cylindrical throwing sticks, have longitudinal grooves or flutes carved into them. The grooves are about five millimetres wide by 0.2 millimetres deep, and occur only on the upper, more highly curved surface of boomerangs but all the way round the circumference of throwing sticks. Previously these grooves were thought to be purely decorative or of ceremonial significance. But new research by civil engineer Ray Nelson (University of New South Wales) has shown they are more than just decoration-they enhance flight performance. tat's wat grooves mean..lol should've googled it XD
Aug 5, 2008. 7:39 PMyeerk21 says:
wat r grooves?
Mar 20, 2010. 1:34 PMFFVIIBOY says:
i think grooves are wen you make the corners round. I dont know im just guessing
Mar 16, 2010. 2:54 PMFFVIIBOY says:
I just got a file on instructables last month but i thought id tell you that last summer i made this and it wuz so much fun using it but it kept klanding on my roof or tree across the street frum my house which is lik 40 feet high so it wuz hard to get that out eventually it wuz winter i needed rulers for school etc. but its sunny out now so il be makin it again soon
Jun 27, 2009. 8:51 PMGEEK1 says:
Can you use 7.5" wooden coffee stirrers?
Apr 5, 2009. 3:58 AMunknown24 says:
amazing!
Mar 20, 2009. 7:51 AMrensje says:
my boomerang flies, but after turning it just falls down. does it need more speed?
Jan 27, 2009. 4:32 PMyukas says:
:D
Oct 8, 2008. 3:09 AMknexcthulu says:
paddle pop sticks also work
Nov 12, 2008. 12:50 AMitachirox says:
paddle pop sticks didn't work for me as a boomerang but a shuriken
Oct 8, 2008. 2:17 AMknexcthulu says:
what do you mean by paint sticks?
Sep 2, 2008. 5:57 PMsteed1172 says:
awsome! i gotta try it....i only have one paint stick atm...*some one* broke the other.
Aug 25, 2008. 12:11 PMcman23 says:
it wouldn't work for me
Aug 22, 2008. 10:23 PMsissysissysissysii says:
This was the most ingenious invention i've read so far! keep up the good work! I look forewards reading even more amazing things. Thank you!
Aug 24, 2007. 10:04 PMcj360 says:
sorry man but this one is the last one .you said to add groves.did you mean that instead of using rubberbands i will have to add groves.reply me last time.
Aug 5, 2008. 7:38 PMyeerk21 says:
can i use rulers?
Sep 21, 2007. 11:12 PMBoomGuy says:
I'm not sure string would hold up. You can glue them together. When I make boomerangs out of paintsticks I put them down mark where they overlap. then I take out wood on both sticks in the overlapping region and glue them together there. Sort of a lap joint.
Aug 5, 2008. 7:37 PMyeerk21 says:
square lash it
Aug 23, 2007. 6:26 PMac1D says:
From the time im 9Years old, during the summer, when the school end, i build those. i build around 100, and when the school start, i sell them five follars each. Rly cheap to build (you go to RONA or what ever, you ask for 200 paint stick for a project, and they gave them to you for free!) and you buy a bag of 250 elastic for 1$ at dolorama!
Nov 28, 2007. 2:27 PMfordman15243 says:
no, that's awesome!
Jul 16, 2008. 11:40 AMAll4Shrimp says:
no, that's thinking.
Jun 12, 2008. 11:29 PMXx knex guru xX says:
It works but it looks weird
Jun 5, 2008. 6:48 AMthedog458 says:
nice 5/5 10/10 grate inscrutable it looks like it works heps good
May 30, 2008. 9:21 AMnat96 says:
awesome man 2 thumbs
Mar 8, 2008. 6:31 AMpyro 360 says:
NICE I used rolled up paper coz I dint have any wood so yeah it works awesome and its more aerodynamic
1-40 of 65next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:RazorG606
