3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Make a Cryptex
Step 2Materials and Tools
Materials and Tools
These are the things I used to make the cryptex. If you don't have some things, there may be another way to do it, just look where I used the material or tool, and look if you can think of a surrogate.
The choice of the four tubes is really important. They have to fit in eachother, with not too much space between them, and also not too little(they still need to be able to move in eachother.) The two outer tubes are an exception to this, they may fit real tight. I have the outer tubes as PVC tubes, I think that's the best choice, and the inner two tubes I have in metal. The second smallest tube doesn't need to be in metal, but the smallest is better in metal, I think. That is because we will hammer 6 nails through it, which need to stay in that place. That's why we solder it from the inside, to that the nails stay in place. you could use a PVC tube for the smallest tube, but then it better have a thick frame, for the nails. These nails are so important because they are the tabs that go through the notches on the rings. They may not break.
13 comments
Jun 4, 2010. 11:42 PMmaddiemanahan says:
Where would you recomend buying the four tubes ?
Jan 8, 2012. 9:42 AMtech dawg says:
I have made a lot of different things with tubes and I always go to LOWES.
Aug 27, 2010. 12:04 AMkooldoode says:
i would say home hardware in the plumbing section, or any hardware store,if you cant find any ask a clerk or someone
Jul 24, 2009. 11:08 AMthemonorail says:
does it destroy the message inside if you break it like in the book?
Jul 24, 2009. 11:44 AMAlternateLives says:
Not exactly. however, read the whole intro of this insructable to get the whole story on the ink.
Jul 29, 2009. 8:25 AMcdousley says:
replace the ink with viniger and cover the message in baking soda
Sep 24, 2009. 7:41 PMSomnicule says:
Or you could put ink in the vial.
Jan 16, 2010. 8:42 PMcdousley says:
inky vineger?
Mar 22, 2010. 11:29 AMKing Julien says:
just ink
Mar 26, 2010. 10:51 AMcdousley says:
just inky vineger.
Nov 30, 2009. 7:05 AMNick692 says:
Can anyone give me any tips on where to buy the 4 tubes that fit into each other? Are they readily available at hardware stores, or are they hard to find?
Dec 1, 2009. 6:15 AMIridium7 says:
 try home depot. should have plenty of tubes.
Dec 2, 2009. 2:14 AMNick692 says:
I live in the UK so I don't think they have home depot's here. Can I order from their website even though I live internationally?
Dec 2, 2009. 11:44 AMmyckro says:
Hi, just go to any hardware store and see what you can find... I didn't find the exact fit for the plastic ones (Two outer tubes) so I had to fill them but it worked okay! Good luck. Ohh I also had to go to 2 hardware store, i bought 2 from one place 1 I found in a construction site and the other from another store!!! Take care! (If you want to see mine http://www.instructables.com/id/My-very-own-Cryptex/)
Just go for it!
Dec 2, 2009. 5:09 AMIridium7 says:
 ah... well I don't know that sorry. strange they have them there.
Jul 21, 2009. 9:08 AMsteampirate says:
Are those citadel paints in the picture?
Jul 24, 2009. 12:02 PMThomasvanZwol says:
Yes they are, well seen ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
166
Author:merijnvw(my company)
I'm Merijn van Wouden and I live in The Netherlands. As my job I make websites. I study Artificial Intelligence.
