How to Make a Desktop Catapult
Published
Introduction: How to Make a Desktop Catapult
About: Hi I'm Linn and on my Youtube Channel I have lots of great videos about building, construction and fun projects. You can also check out my site @ http://darbinorvar.com
Here is a simple DIY desktop catapult you can make with just a few hours and some easy-to-get materials. In the video I used mortise and tenon joinery but you can get good results with just glue and brad nails.
Step 1: Making the Catapult
Tools
  • Table or Hand Saw
  • Drill
Materials
  • Oak or other hard wood
  • Rubber Band
  • Short Twine or small rope
  • Metal Latch release or gate release
  • 3/16” metal rod
  • 3/8” metal rod or 3/8” oak dowel
Cut List
  • Base – 5 x 1 3/8 x 8 ½” Oak, mahogany or laminate any wood together
  • Boom, Catapult Arm – 12 x ¾ x ¾”, you could also go ½” square for a smaller machine
  • 2 Long Post – 5 ¾ x ¾ x ¾”
  • 2 Short Angle 3 x ¾ x ¾”
  • 2 Long Angle 5 ¾ x ¾ x ¾”
Method
Cut the 2 long posts square and glue to the base, use some screws or brad nails to secure. Cut the 2 long angles and 2 short angles at 45 degrees and attach to the long posts on the base. Use brad nails or screws with glue for the best result. You can always add additional support if needed.
For the rubber band, just use a common office version and for the cup either buy a thick piece of lumber or laminate thinner pieces together. Drill out a 1 ½” bowl and screw to the boom/arm.
Step 2: Conclusion
For a more in depth look, check out the video that goes over all of the steps to make this desktop catapult!
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
