How to Make a Little House in Minecraft
9,534
4
11
Posted
Introduction: How to Make a Little House in Minecraft
This Instructable will show you how to make a house in minecraft.  In this example we are making the house out of TNT.  You can make yours with any block you want, even a mix!  You should make sure you are on creative mode.  You can also do this on survival mode, but for now we will be using creative mode.   You can make the house out of any block, even TNT (dynamite)!  You will need:
Minecraft (Duh!) (In creative or survival mode)
The block you want to make the house out of
Stuff to put inside  (Like glow stone or a torch for light, a chest to put stuff in, a jukebox, ext. Do NOT use a torch for light if the house is made of TNT, like in the main picture!!  The fire will make it explode!  You do not need anything to light it if the house is made out of glow stone, however.)
Something to play minecraft on (Again, Duh!)
Flat Space to build the house on (Superflat-type world recomended, but not needed.)
Time
Hands to hold the mouse and to use the keyboard (Once more, Duh!)
Step 1: Make Your Building Space
First, you should make your building space, by breaking the blocks in the ground in whatever shape you want your house, as big as you want it. It HAS to be only one layer down!  (You can make it more, but I don't recommend it.)
Step 2: Fill Your Building Space to Make the Floor
Now , you want to fill the building space, to make a floor.  You have to fill it to ground level so it is easy to get in and out of your house.
Step 3: Make the Walls
Now, you want to make the walls, by making layers on top of each other, but DON'T fill the inside.  you can do this as many times as you want, to make the walls as high as you want them.
Step 4: Add the Roof
Next, cover the top of the house to make the roof.  Before closing the roof, put a light source in the house, so when you close the roof, it's not pitch black.
Step 5: Add a Door Hole
Now it's time to add a Door Hole!  Break an at least  two block high hole in one of the walls in your house, starting from the ground up.
Step 6: Add a Door
Time to add a Door!  Go outside of the house and place the door on the block right in front or the door hole.  The Door does not have to be an iron door, it can be wooden.  Sadly, I don't know how to make an open able door, someone else has to teach you, and me how to do that. Sorry about that.
Step 7: Your Done!
You have now made a house on minecraft!  Thanks for reading!
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    12 Comments
    To make the iron door open, just place a pressure plate in front of it or a lever to the side.
    You cant in pocket edition
    (Duh)
    Hey Dude, Nice House. Now all u have to do is light the tnt! :P
    Of course, YOU would want to do that being a Creeper and all.
    if you light it it will kill you!!!!!!!!!!!!!!!!
    This is so stupid. People know how to make a freakin house genius
    To open it u would put a lever or buttun and when u try to open the TNT would light so u would blow up
