Introduction: How to Make the Perfect Peanut Butter and Jelly Sandwich
When I was in first grade I had an assignment to learn how to make a PB&J sandwich. Just in case you never got that lesson in school, or if you have forgotten, I have provided easy step-by-step instructions to make the perfect peanut butter and jelly sandwich.
Step 1: Get the Materials
To make the perfect PB&J sandwich you will need:
-A clean, flat food production surface (I use a clean cutting board)
-Peanut butter of your choice
-Jelly, jam, or preserves of your choice
-2 slices of sandwich bread
-A clean butter knife
Step 2: Prepare the Bread
Position the bread slices on the clean surface side-by-side, with one slice face up and the other face down.
This step is vital because it will allow the slices of bread to evenly match together when combining them in Step 5.
Step 3: Apply Peanut Butter
Using the knife, scoop a large dollop of peanut butter and spread it onto the top of each slice of bread. Use as much peanut butter as desired.
Putting peanut butter on each side will prevent the bread from getting soggy from the jelly- this is especially important if preparing the sandwich ahead of time.
Step 4: Apply Jelly
Using the same technique as with the peanut butter, scoop out the desired amount of jelly. Spread it on top of the peanut butter of one slice of bread.
Putting jelly on both sides will only lead to a mess, with jelly spewing out the sides of the sandwich.
Step 5: Combine Both Slices of Bread
Take the slice of bread without jelly on it and flip it on top of the jelly of the other slice. You should now have a layered PB&J sandwich with peanut butter on the top and bottom and jelly in the center.
Step 6: Eat and Repeat
That's it! Now you can satisfy your hunger with a delicious, non-soggy peanut butter and jelly sandwich. Repeat as necessary until you are full or run out of peanut butter. Enjoy!
