How To Make a Simple Portable Fan
 In this Instructable I will show you how to make a simple portable fan. Warning before taking apart the computer power supply you must unplug the power supply or else you could be really painfully shocked or even killed just from touching one of those silver plates which are heat sinks I learned that first hand but luckily I wasn't killed. You should also use a grounding wrist band with a built in resistor and make sure you keep your hands and tools away from the big black things, they are capacitors which can still hold a charge of about 200 volts at 5 amps which can easily injury or even kill you!! I am not responsible if you get injured or killed.  But you can easily overcome this by using a different fan from inside your computer.
Step 1Getting The Materials
 Here is a list of things you need to make the fan:
One computer power supply or one computer fan (if you are using a computer fan then skip steps 2 and 3 )
Eight AA batteries
One battery holder for eight AA batteries
Tools:
One Phillips screwdriver
Side-cutters
Masking tape
12 comments
Feb 17, 2011. 1:36 PMworldthisofout says:
do you need 8 batteries?
Sep 18, 2010. 5:20 PMaccount3r2 says:
or 1 A (23A) battery. they are 12 volts.
Jun 10, 2010. 8:00 PMhatehatehate says:
You DO NOT want to wear a grounding wrist band while working with a PSU. Wearing the wrist band will pass a high voltage charge through your body. You do not want that! While working with high voltage sources dont use a wristband and try use only one hand if your removing a component or w/e. Using two hands will complete a circuit, passing voltage through your body.
Aug 18, 2010. 8:48 PMMACKattacksnipe says:
Still Safty First LOL
Feb 26, 2010. 5:45 AMbertus52x11 says:
 Clear instructable!
Mar 30, 2010. 6:00 PMRoboticKop says:
AWESOME!!!  This is great!!! thanks!!
Cant you use computer power supply and make it run  like a portable fan? What holds 8 batteries or more now  a days? how long does it run for?
Apr 27, 2010. 3:55 PMbigstiffy says:
This is fantastic, I had a dead power supply laying around for a year, now I can finally put the fan to use.
Feb 23, 2010. 7:53 AMrimar2000 says:
Good work!!
Cheap, eco-friendly and useful...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:qazwsx755(qazwsx755's website)
