loading
Step 2: Create the icon
You can download the icon below this just how to make it.
To create the icon open up The GIMP. It can be downloaded HERE.
Now open up the layers dialog (Follow the pictures)
Delete the background layer.
Save as .ico.
Now the icon is made! You con exit Gimp.
If you forgot where did you put it you can select all the desktop than you see it
 there's such a thing as digital camouflage
Yep, and I'd like to offer one* digital trip-wire to detect the camouflaged:<br> <br> click in empty space in a corner and slide it all the way across the screen and the blank name-space be highlighted revealing the folder.<br> <br> <br> <br> *also I tried CD-ing to the desktop folder using DOS, I could see a folder with no name, and without a name I could not access it that way, only detect it.
You must realize that when posts are over a year old, the guy would have figured it out by then. Actually, it kinda depends on the guy you're talking to. In this case, 1 1/2 years is enough for me to understand that using True Crypt is way better by 512 bits, as well as a load of other tricks up my drive.
i dont know if everyone else is the same but when i click change icon, there are some blank spaces on the icon list, but if you actually use a blank one its totally transparent, <br>and for some reason i cant put an empty caption on folders but i can on shortcut files.
interesting...
cooooooooooooooooooooool!!!!!!!!!!!1
Hey if you lose the file you can click any where you think it might be and drag creating a field that selects all files in it! And no i didn't lose mine.
Nice instructibles. i always want to make a shortcut, so when i double click it it looks like i double click a picture in the background. but the only problem is i cant use space alone as the name, so i use comma instead. now i know how to make space as recognizeable filename. thanks
Hey this may sound stupid but how can i get a screen shot of my desktop?
the butten next to f12
Also if you want just a picture of the window in the foreground then go Alt + Print Screen.
whats this alt thing? u just press Print Screen on ur key board and paste it in paint silly
Pressing Alt makes the computer just take a picture of the active window. At least in Windows XP.
OH!!!! sorry i didnt realize that :S
That's OK
Press print screen (print scr) near the top right corner of your keybourd. Then go on paint. Go to edit, paste on ther menu bar. there's your screen shot.
Thanks this will so be useful!
you guys should check out my instrucable unclickablefolder
...<br/>what instructable?<br/>when i click on your name it says that you have not<br/>published any instructables<br/>=P<br/>
The same thing is happening to me.
there should already be a transparent icon option built into xp i learned about this in a video somewhere
nice trick!
a shortcut gives you that stupid little arrow on the bottom of the icon though. otherwise nice idea with the computer code space idea.
To get rid of that arrow you can use the power toy TweakIU available for XP from Microsoft <a rel="nofollow" href="http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx">HERE</a><br/>I'm not aware of any for Vista yet.<br/>
This is a terrible idea because it makes it difficult to delete the folder if you ever want to. If you want to still do this just make sure you know how to delete it later. I went to this website to delete a folder I changed the name of<br/><a rel="nofollow" href="http://www.vistaheads.com/forums/microsoft-public-windows-vista-file-management/202037-how-delete-folder-no-name.html">How to delete a folder with no name</a><br/>
That method did work for me. Here's what I did:<br/>Open command prompt (All Programs -&gt; Accessories -&gt; Command Prompt or just type <strong>cmd</strong> in Run or in the start menu in Vista and hit enter)<br/>Get to the directory you made the folder in. type <strong>cd ..</strong> to go up one directory and <strong>cd <em>name<em><strong> to go into a folder. If you save it in desktop just type <strong>cd Desktop</strong></strong></em></em></strong><br/>Then type <strong>rd &quot;Alt+0160&quot;</strong> (R + D + double quote + the alt+0160 character + double quote) and press enter<br/>If there is no error then the folder got deleted<br/>
Great instructable. This is probably a really dumb question, but how do I download the icon.ico file?
You right click and go save as. When you go to make it as your icon go file of types and select all files. I didn't realize that it didn't automatically download it. good question.
I noticed that it appears that your using windows, but Alt + 0160 wouldn't work for the folder name. any suggestions? everything else works awesome, thanks!
Did you <strong>hold down</strong> the alt key while typing 0160 on the <strong>number pad</strong>?<br/>
Note that this throws a file in the folder called Desktop.ini. You can copy this file to other folders to make them transparent as well. Nice idea.
About This Instructable
5,575views
19favorites
License:
More by computergeek:DIY Apple Remote (Slideshow for the instructable) DIY Apple Remote Shield for the Arduino Simple 2-way motor control for the arduino
Add instructable to:
