The instructable shows how to adapt an ordinary eye loupe to an illuminated LED eye loupe. After I made one, I was surprised at how much better the magnified objects look due to the illumination.
Remove these ads by
Signing UpStep 1Components and Tools
1. SMD White LEDs PLCC package - 8 numbers
2. SMD Resistors 100 Ohm 1206 or 0805 size: 8 numbers
3. copper clad board (stock PCB), cut an annular shape (see the next step for the dimensions)
4. ordinary eye loupe
5. Battery holder (4xAA battery holder)
Material:
1. Multistrand connecting wire with plastic insulation, 2 colors - 1 feet each
2. Instant glue
3. Solder iron and wire
4. wire cutter
Clamp steadily the PCB to the vertical drill; drill out the smaller (inside diameter) with an appropriate diameter circular drill saw, then with an intermediate diameter circular drill saw scratch (do not cut) the insulating dip on the PCB then finish the ring with the larger outer diameter circular drill saw.
You'll remain with two concentric conductive rings on the copperclad board suitable to hold the LEDS connected in parallel.
Sorry, I'm missing some technical names for the things and I could not take advantage from wikipedia/google images...
Hola everyone !
A.
What is it in Espanole?
Your English is better than my Espanole.
Where do you hale from?
http://images.google.bg/images?um=1&hl=bg&tbs=isch%3A1&sa=1&q=optical+fiber+lights&aq=f&aqi=&aql=&oq=&gs_rfai=&start=0
BIG BIG diffrence good for dark indoor workshops (how most are)
USB cable
That way it would only be on when you were holding it. And forgetting to turn it off goes away.
Nice Instructable.
would you say this is a good project for beginning solderers? Or should I go out and buy a new illuminated lens? Even if it were more cost effective to buy a new one, I was thinking the experience would outweigh the extra cost (if any?)
What do you think?
thanks!!!
1. Loupe: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=243-1021-ND
2. LEDs: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=CLM3C-WKW-CWBYA453CT-ND
3. resistors: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=RMCF1/8100JRCT-ND
Even of you want to keep it battery powered... the cord from an old wall transformer is usually very nice stranded wire and a good way to recycle. You can often get this from old cell phone chargers... I have made many projects powered with recycled chargers!
For covering the LED's you can also use 2-part Epoxy which is generally glass clear. Just remember... if you do coat them in epoxy... it is NOT going to come off for repair! Also... if you go this route... apply it before you attach it to the eyepiece so you can trim it, and so you don't get epoxy on the glass while doing the job.
Jerry
Any particular reason you used the surface-mount components rather than the more hobbyist-friendly wire-lead versions?
1. Leaded components, I thought, would protrude too much below and interfere with the focusing range so to say.
2. Likely to damage leaded components more than the SMD components again, because of the extra protrusion.
3. The PCB layout (there is not much of a PCB layout really) with the SMD components is fairly simple. With leaded components it would get more messy.
You can see the yellow tinge on the hot glue.
Infact in a more advanced version I thought I might put in RGB LEDs and actually tailor the color of I light I wanted to have for a particular observation....
The next thing I'd do is to mod the battery holders so you have everything into a single piece. Maybe you could use single battery holders, wire them in series and attach them to the body of the loupe at 90º angles each.
