loading
Step 3: Background: How a Fig Rig Stabilizer Works
In a Fig Rig system the camera is mounted on a platform at the center of an 18.7 inch (475mm) circle of tubing. The hand grips are located on the right and left side of the rig in line with the camera. By having the hand grips further away from the camera, the Fig Rig is able to dramatically reduce camera shake that is caused by random hand movements. It is also a much more comfortable method of supporting the camera. This reduces fatigue on the operator.
A typical point and shoot camera is about 4-5 inches wide. So widening the base to 18 inches can reduce the effects of random movements of a hand by as much as 75%. (A 1/4 inch vertical movement on a 4 inch base produces an angle of 3.58 deg. A 1/4 inch vertical movement on an 18 inch base produces an angle of only 0.80 deg.)
Yes, you could add handles. I was just trying to make it as simple as possible to help illustrate that you can use just about any materials at hand. <br><br>There are already several designs for a PVC Pipe version that you can check out. <br>http://www.instructables.com/id/Build-a-PVC-Fig-Rig/<br>http://www.instructables.com/id/PVC-FIG-RIG/<br>www.youtube.com/watch?v=qT72hoYxESI
great idea man :)
About This Instructable
76,888views
49favorites
License:
Bio: My name is Jason Poel Smith I am a Community Manager here at Instructables. In my free time, I am an Inventor, Maker, Hacker, Tinker ... More »
More by DIY Hacks and How Tos:How to Make a Festivus Pole Add Wings to an Infant's Halloween Costume Bubble Bath That Never Runs Out Of Bubbles
Add instructable to:
