3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Mod Sony Ericsson Speakers To Work With an iPod.
In this instructable I will be showing you how to mod a pair of Sony Ericsson Speakers to work with iPods, MP3's or anything that has a headphone socket!
This is my first instructable so I hope you like it!
Equipment:
Any cable with a 2.5mm jack on the end
Pair of Sony Ericsson speakers (I used the MPS-60)
Scissors (or wire strippers)
Electrical Tape
A lighter or matches.
Soldering iron (optional)
Sound output.
I would like to mention at this point that this instructable was produced a long time ago now, my skills are far superior to those displayed within the instructable. I might later upload an instructable relating to small portable speakers with a built in amp (3v button cell maybe?)
Step 1Cutting the Speakers
This step can be done either with a screwdigger or with a T screwdriver (buy a whole set, they come in useful and I don't know what size.)
Unscrew the casing for the speakers, and cut the wires connecting them to the PCB (I believe this is an Amp, so I'd recommend you buy a small Amp later.)
Now get your scissors and and carefully strip the insulation from the outside of thecable leading to the speaker, make sure not to cut the cable, then cut the inner part of the insulation and seperate the two, now stripped, wires. (Note: this can be done much better with wire cutters or a stanley knife.)
10 comments
Apr 5, 2012. 4:26 AMArchie_UmeshNair says:
See attached image for exact pinouts....
For more details / information refer to the tutorial at the link below;
http://suhastech.com/stereo-input-port-for-the-sony-ericsson-portable-speakers-ipod-headphone/
Aug 20, 2011. 1:30 AMC00K13 says:
what enamel??
Aug 20, 2011. 1:28 AMC00K13 says:
what do i do if i have a wire that is part black part greenBlue stuff??
Jun 28, 2011. 10:32 AMmrodríguez22 says:
Hi, I didn't open the speakers I just cut the cable of the speaker in which I found blue, green, red, black and gold wires. I connected the blue and green wires to a jack from a headphones and the black and red to a usb cable (the one who comes for data transfer with the phone).Usb cable=5v , the power that the amp needs=5v. I want to improve my laptop audio which is so low. I though my idea was going to work just fine but it didn't, I just don't know why :S
Sep 25, 2010. 9:32 PMYamahard says:
Thanks heaps bro, took me all of about quarter of an hour slowly and peacefully constructing. Havent soldered it yet cause I need to by one (but yes I've used them heaps before, and I have the scars to proove it :D ).
And the enjoyment I have been getting from the so far is astronomical.
Notes from my build:
My jack for the input only has 2 cables which makes it so easy, and I have tested both speakers (aswell as together). Next step is to solder, then win the ladies over with my awesome portable speakers :)
Sep 12, 2010. 12:16 PManonymouse197 says:
Hi!
I like this instructable but could you tell me - Are you connecting the 'three coloured wires' to two connections on your jack? Do you actually use your earthing/negative wire?
Sep 13, 2010. 10:19 AManonymouse197 says:
Hi,
Dont worry about that question - I worked it out!
This is a really handy instructable, so thanks. I would never have thought that the speakers would even work without the amp bit,
Thanks again!!
Apr 1, 2009. 2:39 PMJoe Martin says:
Very good, Although if you kept the ap they would of been A lot louder (and trust me, the walkman one's are)
If you still have it and wanna try it heres a pinout for the connector here, note that is the connector for the phone so it will need to be reversed for the amp.
The amp needs 5V (From memory) to run, supply this into pin 11 and the get audio in I believe you need 2 & 8.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:xAxrules
