3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Paint Your Valve Cover
I've had this idea for a while, and I figured I might as well get started. I'm going to show you how to paint your valve cover. I'm doing this on a 1989 Honda Prelude 4WS Si and on a 1995 Honda Accord EX VTEC. *NOTE* Please let me know if I missed anything. I'll add it in as soon as I know about it.
Step 1Collect your materials!
  • last photo ←
First off, this isn't going to be a really simple job. If you can't use a spray paint can, a screw driver, or a socket wrench, have someone else do this. If you mess up, it's not going to look good, and will be quite hard to fix.
Here's what all you should need:
Valve Cover
Hi-Temp spray paint ( I used Dupli-Color Engine Enamel)
Aircraft Remover (Yes, that's what it's called. It's paint remover.)
Windex! (Regular Windex)
Flathead Screwdriver
Old Towel (Clean is best!)
Socket Set
Hi-Temp primer (I used Dupli-Color flat gray primer)
A Wire Brush
Two portable clean hard surfaces ( I used an old tub lid, and a water damaged bit of fiberboard)
Daylight! Don't do this at night!
Lots of paper towels.
17 comments
Mar 30, 2011. 11:55 PMtinydreamstudio says:
Did you need to remove the spark plug prior to doing this?
Mar 2, 2010. 11:43 PMKibbe17 says:
How many cans of each item (remover, primer, paint) Did it take you for all coats??
Jul 6, 2009. 11:50 PMYerboogieman says:
Make it a Ram air intake, put it in the bumper to catch the air as the car moves forward.
Feb 28, 2011. 10:31 PMNapenE04 says:
only if you do actually do this, you will need to keep in mind on rainy days not to run through deep puddles because then you could end up getting water up in there... not so good.
Nov 1, 2009. 9:00 PMslavrenz says:
You should wack that valve cover with a rubber mallet to remove it instead of using a screwdriver. The screwdriver could gouge the head, and the gasket won't seal that.
Feb 28, 2011. 10:30 PMNapenE04 says:
lol 'wacking' is not so good.. but giving it a gentle tap is a great idea
Feb 15, 2011. 1:34 PMthe420guru says:
did you just bend your airhose so that its pointing straight down?
or did it come like that stock?
Jul 23, 2009. 7:30 PMsoadjoe says:
You also need new valve cover gaskets if you are to do the job correctly. At least for most cars. Reusing gaskets are bad.
Jul 10, 2009. 2:06 AMcrazedchikn says:
WOO VTEC. :D
Nov 27, 2008. 5:49 PMTheWelfareWarrior says:
Well, you CAN mess up the firing order and it will run... My dad left his car at a friends house while he was in Mexico, after a week the battery was dead and he had "disabled" his honda civic by unpluging two of the plug leads... I did not know that and push started his car uphill... and it worked... it ran, but barely. Smoked his O2 sensor.
Nov 27, 2008. 7:44 PMTheWelfareWarrior says:
Yeah, my uncle did that on a 350... peeled his muffler apart... sounded like a bomb.
Nov 27, 2008. 4:55 PMkillerjackalope says:
Good job, granted painting your valve cover could be an innuendo...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:gtkid2002
