Step 3Removing the Valve Cover
Now you'll need to pry the valve cover up a little. For my car, I had to use a flat head screwdriver to pry the valve cover up, and break the gasket seal. Now, my car has a rubber gasket, so I do not have to worry much about ripping it. You might have a non-rubber gasket, and if you do, you will want to get another to replace the one you're probably about to rip. Now, using the flat head screwdriver, pry the valve cover up on the driver side. Then the passenger side. It does not matter which side you start on. You may need to pry up on the rear of it, but I did not.
You will probably have to wiggle the valve cover a lot to get it off. Once you've removed the valve cover, place it on a clean hard surface, I used a tub lid for cleaning, and a chunk of fiberboard for painting. Cover the valve cover with the towel, so no passing dust gets into it, or paint particles. It is crucial that you have a towel for this job.
comments
Add Comment
Add Comment
