How To Play The Harmonica
 by misteravocado5
After searching around on instructables, I didn't find any complete harmonica tutorials. There are quite a few good ones around the internet, but I thought there should be an instructable.
So. The harmonIca is one of the easiest instruments to play, it sounds really cool, and can be used for a variety of musical styles. All right, maybe not too many musical styles, but it's fun to play anyway. So. Here we go.
Step 1: Types of Harmonicas
Diatonic: This is the most common, simplest type of harmonica. You'll probably want to start here. A diatonic harmonica has 10 holes. It is built to play a major, diatonic scale. Additional notes can be played by "bending" (explained later) and different scales can be obtained by playing in different positions (explained later).
Chromatic: These are fancy harmonicas. They have a little button on the side. When you press this button, whatever note you are playing moves up a half step. This allows you to play every note in the musical scale, a chromatic scale. Although they offer more versatility, they are often harder to play, especially if you are trying to bend. Not recommended for blues.
Tremolo and Octave Harmonicas: These harmonicas have a double row of holes. On a tremolo, the notes are tuned slightly apart, but almost the same, creating a cool "tremolo" vibrating effect. On an octave harmonica, the notes are tuned an octave (8 notes) apart, creating a fuller sound. Compare to a 12-string guitar. Both are sort of rarely used.
Special tunings: Some harmonicas come with different scales like minor scales and scales made for playing in more than one key.
Bottom Line: Start with a diatonic harmonica, preferably in the key of C (as this is the easiest key to understand).
Here are some pictures of each type.
metalhaid says: Jul 10, 2012. 1:44 PM
This is great! I just wanted to comment that I think the reason the harmonica goes to a C on 7 is because there is no sharp between B & C (at least there isn't on a piano...) thanks for the lessons!
freeza36 says: Jun 15, 2012. 1:08 PM
I just bought a Hohner Diactonic harmonica, and i am already hooked on it. It is so easy and fun to play. Within a day, i could already play a couple tunes.
nof-z says: May 7, 2012. 11:09 PM
when to mijer and saw they had harmonicas for two bucks, an i thought "well, i haven't had one of these in a while" so i got one, and found your instructable, and now i am hooked. you were vary clear and easy. thanks for teaching me!!!
11richie21 says: Nov 15, 2010. 7:07 PM
Hi, I have been planning on buying a harmonica just to begin thanks to your instructable. it has helped me learn how they actually work! I thought people would just play random sounds and master how to play haha seems I was wrong.
misteravocado5 (author) in reply to 11richie21Nov 16, 2010. 7:05 PM
Thank you for the feedback, it means a lot. Good luck!
rimar2000 says: Jun 22, 2010. 10:05 AM
Good instructable! I have a little 10 holes harmonica, but I could never learn to play by music, only played a few pieces by ear. Maybe your instructable makes me encourage...
misteravocado5 (author) in reply to rimar2000Jun 22, 2010. 8:16 PM
Thank you! Glad to hear that it's encouraging someone.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
