How to Port a Game in Wineskin
191,574
10
15
Posted
Introduction: How to Port a Game in Wineskin
Hello you got a game that you bought and then it's Only supported for windows fear not there's an Mac app called wineskin winery. In this Instructable I'll teach you how to port a game using this application, I'm gonna use Skitch for most of the images for this so I don't have to write what to do.
Step 1: Now Pick a Game That You Wanna Port on Wineskin
Before you even make the wrapper you'll need to pick a game you want to port to the Mac using this application, once you have your game of choice goto the next step about download and using wineskin winery.
Step 2: Downloading the App
goto this website to download wineskin Winery for Mac http://wineskin.urgesoftware.com/tiki-index.php?page=Downloads
Step 3: Using Wineskin Winery
unzip the file and put the app inside your main Applications folder and then open the main application from it. and then you'll see a window with no engines installed (in screenshot number 2)
Step 4: Installing a Wine Engine
Installing one is really easy do. Just click on The plus and install any engine you want from the popup menu.
Step 5: Create a Wrapper
Once you have your downloaded Engine like WS8Wine1.5.2 you now create a Wrapper that will be used for your game, a wrapper contains the wine tricks, windows system files and other things.
Step 6: Once Created Open the Empty Wrapper
Once you create the wrapper Wine may display that didn't find the gecko HTML engine or whatever it is just install it. it will help the Help screen a lot since it uses HTML based coding on the game you're importing as a Wineskin Wrapper. When the Wrapper creation is done it will tell you it's ready in /users/your username/applications/wineskin
Then when you're at the wineskin app we'll need to install some Winetricks (that will be in the next step)
(In most times you may need Gecko Html for the help files which it's powered by Html so the engine will help it if you're having trouble with the game.)
Step 7: WineTricks? What Is a Winetrick?
Winetricks is wine's override of the actual software like Direct X 9 to Windows Media player Codecs. To install a winetrick you'll need to download it first from the main Winetrick window. Once all of your selected winetricks are done you now can install your software inside your wrapper.
To Install Winetricks you'll need to click on Advanced and then goto the tools section (Refer to picture for this) Then click on Winetricks button and you'll see a window to install winetricks.
Step 8: Configuring Your Wrapper
The configuring section of your wrapper contains what is needed to make it like a Mac Game like
EXE Flags - what command line keywords that needs to run like -windowed (for window mode) and so on
Version - what is the version of your wrapper? (I prefer you use the version number of the game's release for this)
Menubar name - It will display the name of the App in the application menu
icon - A picture of your .icns icon for the wrapper
Once you're happy with the configuration you may install the game or make it have a wine desktop or not that's in the Screen options (refer to picture)
Step 9: Installing the Game
When installing ALWAYS make sure to install it in drive C: not Z: which is your main volume so be sure to use the installer's default location.
If an installer installs any shortcut or other junk on the desktop you may remove them since these won't work like those shortcuts which are .ink files.
Step 10: Done and Ready to Play.
Once you have the game installed make sure you pick the right .exe that is the game itself most games will crash because it must rely on the CD like Need for Speed Carbon which you need to use a No-CD Patch or like Monopoly Tycoon patch it to 1.4 and disable the intro movie or it will crash.
Here's Monopoly Casino running in a wineskin wrapper.
This is a screenshot of Lights out Slot machine.
Step 11: Bonus: Referring to WineHQ's App Database
You may have to ask why? The reason I'm saying to refer to the database is to what other wine versions other people used to get the games running and post results like Command & Conquer
The Database can be helpful when you're trying to port and run the game so it runs as a native Mac app.
http://appdb.winehq.org/objectManager.php?sClass=version&iId=246 - This is for an example.
When Referring to this Database it will help you along and run many games you have laying around BUT you need to experiment with the game if it's NOT in the database like Monopoly Casino to NASCAR Racing 3 (for which I can't run for some reason)
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Gluten Free Challenge
15 Comments
How to know which winetricks to install?
use the WineHQ database
http://appdb.winehq.org/objectManager.php?sClass=application&sTitle=Browse%20Applications&sOrderBy=appName&bAscending=true
- then search your software/game (using it's search box but full name apps or just find it within' the list below) and see if there's needed winetricks to install.like for Example NFS Carbon says that you'll need to istall Direct X but DO NOT use the official one just say no and just install the game then use Direct X 9 winetrick and I sometimes use Version 8 to boost Direct X a bit.
(Had a bit of trouble getting that link formatted sorry about that)
I'm still confused on what winetricks to install. I'm using Wineskin on Rigs Of Rods 0.38. Can you tell me which one?
https://appdb.winehq.org/objectManager.php?sClass=version&iId=26074 It says from here if you need any try doing direct X 9 and 10(it just makes it a bit better with newer version) then once done test run it to be sure it runs well and quit to view the logs if anything went wrong
Ok so I am in this page but what do I do from here?
How do I download the wine tricks?
It's all in the advanced setting of the wineskin settings app just click on wine tricks and check the ones you need from there so it's this
Wineskin.app>advanced>winetricks>then install what you need by checking it to run.
Is it ok to close the "wineskin advanced" window when i am done?
yeah, all it is the wrapper's settings to do a lot of things, like installing a winetrick.
Hi there. I was just wondering if this is suitable for games like Commnado Behind enemy lines? I want to play this game on my mac laptop and being new to mac and applications Im not sure if it will work.
Thanks in advance for help
