How to Repair Computer Registry Easily in 10 Minutes?
Published
Introduction: How to Repair Computer Registry Easily in 10 Minutes?
Are you looking for the fastest way to repair computer registry? The files in this component are very susceptible to damage and being corrupted. Cleaning it should be done on a weekly basis to ensure that it stays in optimal working condition.
I remembered when my PC registry became damaged. That was when the whole system started to run really slowly, and many error messages were popping up. It made me so frustrated that I almost bought a new PC. Luckily, I managed to find a simple solution, which will be discussed further in this article.
Step 1: What Is the Computer Registry, and What Is Inside It?
It stores many files and entries which contain sets of instructions that are required for your hardware and software to run properly. Some of your programs may even share the same instruction files to run correctly. If you un-install a program from your PC and the shared instruction files are removed together, it will cause computer errors the next time you run other programs that were using the removed instructions.
Other Common Problems Caused By A Damaged Registry?
Other common symptoms that these errors cause are the slowdown in computer processing speed, the Windows Blue Screen of Death, restarting of the computer even when you did not instruct it to, and the frequent hanging of the PC.
Step 2: How to Fix These Errors?
It is not necessary to replace the whole PC due to registry problems. You also do not need to call a technician and pay a hefty repair price. Due to the frequency of such problems, several reputable companies have developed software called registry cleaners that are programmed for the sole purpose of removing such errors.
Step 3: What Can This Software Do for Me?
The first thing you need to do is to download and install them. When you run it, you will be prompted to run a scan on the computer. The cleaner software will then do a full scan in your registry. After that, a report will be created to tell you all the errors it has found.
Depending on the results of the scan, the software will suggest the steps you should take to clean up the PC. If there are truly many errors in your registry, you should proceed to do a repair.
You can also set it to run a scan and fix every week to ensure that your system is kept error free.
Step 4: Conclusion
Nobody knows when your computer registry errors will seriously damage the system. It is highly recommended that you download registry cleaner software to become protected against such a situation. To download the top rated software that I had personally used to repair my system, visit the website link below to learn more.
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    4 Discussions
    k8bdr9
    2 years ago
    Good info for the Tech, but for normal users CCCleaner is the best! We service 100's of computers on a weekly basis and this is a must go to tool for us on computer and laptop registry issues.
    If anyone around Denver needs help or tips on how to use this tool give us a shout:
    http://www.likenewpcs.com
    CCleaner also helps you clean registry and unwanted internet files and caches from your web browser too. Happy New Year 2015 ..
    I also remember the time when all of a sudden my PC used to restart automatically, and BSODs were frequent. Someone told me that it is because of bloated Windows registry. Heck!! Fixing PC Registry manually was one of the toughest thing i had to face. Tried but Faild, Heming my friend told me the name of a safe registry cleaner vix Registry Recycler. The problem was fixed right away when i ran it on ma PC. So repairing with Registry Recycler is a good practice as far as my experience is concerned.
    http://www.itninja.com/blog/view/registry-recycler-best-free-registry-cleaner
