Well, I found some info on the net which brought my Lego Mindstrom LCD back to life. Problem was, the fix didn't last for long. So, in this instructible I'll discuss the conventional wisdom, plus, my own finding to help you bring back your Lego brick back to life.
For reference, here is the link to the original post: http://blogs.wsd1.org/etr/?p=495 This post has some good info and is worth reading. However, their "fix" is to simply re-solder the LCD caps inside the brick. Seemed strange to me that re-soldering ceramic surface mount caps would make a difference. But, I must say, it did work the first time I tried it. This fix lasted for about three months. Then, the LCD started flickering and fading again.
Since my Mindstorm's display was failing again I decided to perform a better fix by replacing the goofy caps. This "better" fix only lasted about a week.
There must be something else going on with the display besides those caps.
Upon close inspection, I believe the true cause of the display problems is not the caps at all, but instead is the LCD connector ribbon cable. I think that fooling / re-soldering the caps simply flexes the ribbon cable which gets the display working again. However, overtime, the ribbon cable comes loose again.
Well, anyway, below are a bunch of pictures that should help you get your Mindstorm back up and running again, one way or another. Oh, and standard disclaimer here - do this repair at your own risk. You could make matter worst for your brick.
Remove these ads by
Signing UpStep 1Dissaembly
The hardest part of this whole repair process is separating the LCD / PCB from the Mindstorm. The PCB fits tightly on locator pins and the LCD is stuck down with double face tap.
Don't be shy, that LCD and circuit board gotta come out! However, don't be too rough either - the LCD ribbon cable is delicate.
The good news is, just send your brick back to Lego and they will repair it for free.
Jim
VERY GOOD NEWS!
Just call Lego Customer Service, they will replace the Intelligent Brick for FREE.
The have admitted it is a common problem due to a bad design of the product and they replace the brick EVEN if the standard warranty period is expired (I bought my brick in 2007, now it is 2012!)
Sorry to interrupt this interesting and challenging project.
Ciao
Paolo
A three minute phone call got me a replacement ordered. Thanks again.
Thanks for the feedback,
Jim
Interruptions like your's are super welcome. I actually boxed up my old brick for spare parts and bought a new one!
After my old brick is repaired, I'll have two bricks. Two are better than one - now we can play with bluetooth messages between bricks.
Thanks so much,
Jim
BTW, I have not actually called Lego yet. I add another comment once I get my brick successfully repaired by Lego. Almost sounds too good to be true. Gotta love Lego.
As is typical of this kinda of stuff, a used eBay brick is probably gonna be cheaper. I just did a search and there are used NXT bricks going for around $100 bucks.
It's too darn bad too. All I need is a source for the LCD and my brick would be just fine. I've found similar LCD replacement parts for well under $10 dollars. However, only the right part number is going to fit just right.
After much searching I think I found the right part number (I think). Here is a link to the LCD replacement part:
http://wandisplay.en.alibaba.com/product/202533550-200851330/productdetail.html
Problems is, I'm betting they are not going to be too happy dealing with hobbyist trying to do their own repairs.
To be fair, I never really tried to order from these folks. For all I know they may be happy to send a couple LCD replacement parts.
Soooooo... Hint, hint, hint. Maybe someone would like to take this one on and order a few replacement displays.
Good luck,
Jim
Mine died again. Crap!
There must be something I can over the old tape to hold it down better. Maybe some epoxy? Maybe a big wad of sticky-tack? Something?
The old tape is just shot.
http://search.digikey.com/scripts/DkSearch/dksus.dll?WT.z_header=search_go&lang=en&site=us&keywords=M970312-ND&x=10&y=15
When I receive it, I'll test it. I'm pretty sure it'll work (based on the spec sheet). I'll let y'all know. I apparently have several to fix here.
The issue, seems to me, is that the existing tape is not holding the mylar ribbon cable down onto the circuit board. Even when the existing tape is reattached it tends to up up again.
I'm thinking of adding a ball of blue-tac right on top of the existing tap. Mushing the case down onto the tac will add pressure onto the existing tape / ribbon cable. The hope it that this will force the combo down onto the circuit board. Only problem is latter opening the case. The blue-tac is going to pull the tape away as the case is opened.
The blue tac is not the best solution - I just can't think of a better one. And yes, my display went dead again too! Gotta find a solution before school starts again.
Tough problem to solve,
Jim
Thanks, Pat
My Lego Mindstorm LCD seems rather dead. If I push / pull on the display just right I might get it working for a few seconds.
Turns out the tape is just a protective cover. Messing with the tape is just a way to flex the internal ribbon cable, I'm guessing.
Have a look at the attached pictures.
Rather a poor design, it seems to me. See how the ribbon cable makes a really sharp bend? Not good.
I did find something that might be a drop in replacement. Have a look at this:
I put in a request for info. However, the rep is in China so communications is difficult. Kinda at my wits ends. Might just end up buying a new unit.
Good Luck,
Jim
any news about this approach?
I did workup the nerve (since my NXT is dead anyway) to pull some of the protective tap off the ribbon cable. Attached are a couple pictures showing the exposed ribbon cable. Notice how the ribbon cable must make a super sharp bend around the plastic LCD housing. I think that is the failure point. If I ever replace the ribbon cable I would first cut some relief into that plastic.
Fooling with, and replacing, the surface mount caps, I think, just flexes the ribbon cable and gets it working again for a short while. I don't think the caps really have anything to do with the real problem. I now believe the root cause of the problem is in the ribbon cable since I can get the display to work (intermittently) if I hold the display just right.
I guess I need to workup some more nerve and pull the ribbon cable off completely. The problem is, I don't have any replacement ribbon cable either. So, once the old ribbon cable is removed, I have nothing to replace it with. Oh, and as you can see in the last picture, the ribbon cable dives into the rubber coating on the LCD.
I'm kinda waiting on mstokes3 to tell us how his tape worked too.
Jim
as you see in the documentation LCD is 100x64dots 26x40.6mm area
3V supply + 9V driving voltage
http://mindstorms.lego.com/upload/contentTemplating/MindstormsOverview/otherfiles/2057/LEGO%20MINDSTORMS%20NXT%20Hardware%20Developer%20Kit%283%29_7A0CF630-CCE5-4AAF-91FA-D1E7C911817C.zip
clearly, by replacing the LCD with the same part will only pospone the problem in time....
we need a "lateral" engineering idea
luca
PS: flexing the ribbon cable I myself can fix or get the problem , just like you did; the problem is really not in the soldering
I've added a new "Step 5" to this instructable that has the attached PDF drawing that they sent to me. So, look for the new step in this indestructible for the PDF.
The attached PDF shows the same pinout as the NXT. The problem is, their minimum order amount is 3,000 pieces!
Anyway, good luck with your NXT display,
Jim
Lisa - Formike formikelcd05@wandisplay.com
Sep 7 to jim.kemp, Burtton
Dear Mr.James,
Nice to meet you. This is Lisa from Formike Electronic Co.,Ltd.
Thank you for your inquiry.
Attached the drawing for your reference. Please help to confirm whehter can meet your requirement.
By the way,would you help to confirm the quantity for your inquiry? It will be our big pleasure if we have opportunities to be on service of you in near future.
Looking forward to your reply.
Best regards,
Lisa Huang Oversea sales manager Sales & MKT Department
Formike Electronic Co.,Ltd. | www.wandisplay.com Room 14H, HanKing Building, 23# DengLiang Road, NanShan District, ShenZhen 518054, China. P: +86(0)755-88306921 Ext:809| F: +86(0)755-88304615 Email: formikelcd05@wandisplay.com | lisa@formike.com.cn Skype: formikelcd05 | MSN: formikelcd05@hotmail.com
I'd try this, since there is a particular pressure point on the ribbon cable that makes everything work perfectly.
Please did you find it easy to remove the LCD from the plastic housing? Any advice?
Luca
The tape holding the LCD down is reusable too. Setting the LCD back down on the tape reactivates the tape. Good as new.
Good luck,
Jim
looking better at the way to cut the plastic and back to the flex, I found that I have a different case than you, perhaps.
And I could solve the problem with a nail.
I tried to draw a sketch and upload it.
If you can see, it's better for me to explain.
The tape "invites" the flex ribbon to make a curve AGAINST the plastic.
The super-sharp bend is done "wrapping" against the PCB (down direction) and then curving upwards against the plastic.
With the nail I could push the tape to avoid the "super-bend" as you called it.
And now it works.
Probably one has to but something to avoid the superbend...
Luca.
Luca.
Yes, please let us know how you make out.
Thanks,
Jim
