How to Restore a Hand Plane
22,337
279
36
Posted
Introduction: How to Restore a Hand Plane
I saw an old hand plane in a used tool store and figured I would have a go at restoring it. I think the before and after speaks for itself. One quick note: When looking at old hand tools to restore, exam them before purchase to make sure no major parts are missing or are too badly damaged.
Step 1: Disassembly
Start by taking apart the hand plane and note any broken parts or pieces. Also make sure and note if any parts are missing. If you are missing any parts shop around to find replacements. In my case the handle was broken so I knew I would have to make a new one later.
Step 2: Cleaning & Polishing
This is the bulk of where the work takes place. I started with the main body of the plane. I opted to sandblast away the old paint. This makes pretty quick work of it. A wire brush or wire wheel in a drill would also work well. The brass parts I polished on a buffing wheel along with steel parts. I also took some time to make sure the iron (blade) was razor sharp.
Step 3: Fixing Broken Parts
On my plane the back handle (tote) was broken. I traced the old handle and cut out a new handle from a piece of cherry. Shaping it, sanding it smooth and it was ready for a clear coat of spray lacquer.
Step 4: Assembly
Once all of the components were polished and cleaned up I laid all the parts out. Then all of the pieces could be but back in reverse order from when I took them apart.
Step 5: All Done!
Aside from it looking 100 times better than when I started it now functions better than brand new!
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
36 Comments
Great Work. Did you put anything on the steel to deter it form oxidizing again? I have an old family plane that i would like to keep some patina on it, but not let it oxidize further. Any help?
thanks - I wiped it down with some boeshield - I have links to it here - https://nickferry.com/my-tools-equipment/
On the one hand I appreciate the craftsmanship demonstrated through your attention to detail/knowledge. On the other hand I always wonder if such endeavors are a waste of time vs buying something new or working with the less than perfect tool. I just got a few planes to play with but I don't quite get the appeal. It was certainly interesting.
thanks man - for a free plane that I use often, it was well worth my time - had it been a plane that was in the family I would have gone lighter on the restore and left more patina - fun stuff either way
2nd life for a 2nd hand planer. I have a few laying around and I will deifinitely start restoring them, now I've read how 'easy' it is, actually.
it's time consuming to take it this far but not technically difficult so I would say give one or two of them a shot - the results are pretty rewarding
If you come across a plane that is rusty I found that Citric acid that you can order in bulk from ebay works amazing, It works better than the many others I have tried and it's cheap....Cover the plane in water, Add 1/2 citric acid powder into the warm water and let soak for 3 hours and go at it with a wire brush of your choosing...
but WHY remove all patina / its historic connection? Sharpening and restoring functionality doesent have to mean polishing It to look like new. My mothe did that to some copper ware and sure Its a matter of taste but I would suggest give It a thought before going beyond whats needed for function.
Is this a Millers Falls plane?
The fact that you even know to ask that question means you really know your stuff. I just restored a 9C for my Dad for Christmas (it's older than I am and he is BY FAR), so hopefully he'll like it. It was this 'ible that inspired me to finally do it, as it's a hand-me-down from my Grandpa, but now it's so nice I can't hold on to it, my shop's too much of a mess for something so nice! Thanks so much for showing us how to do this!
