3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Rewind an Alternator
Step 7Closing Up
Closing Up
First install the Diode pack, then once the diode pack is installed, the end coil wires can be soldered on.
Slide the rotor in to check for fit, nothing touching or scraping, and then the front case half can be installed.
Lastly install the brushes for the field rotor coil and hook up all spade connectors and plastic covers.
The N Neutral conn is used as a voltage sense for the regulator, the F field goes via the alt warning light on the dashboard to the regulator.
The case is connected to batt neg and the big threaded rod from the diode pack goes to the batt positive.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
44
Author:petercd
general bloke type of tinkering
