3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Save Analog Television - Pirate TV
Tired of the blocky, JPEG-like resolution of digital television? Do you long for the days of RF modulation and regulated-yet-unregulated content? Do you simply have the desire to toss your converter box out the window and make use of those rabbit ear antennae that are just lying around? If so, then you might be interested in becoming a savior of analog television! This Instructable will show you how to create your own fully-fledged low-power analog television channel, with any video source(including your computer) as a source of content.
We created one that went live the minute analog tv went dead. We're still the only analog station in NYC, but please join us in making more!! Long live analog tv.
http://OMGimon.TV
Step 1Find A Free Channel.
The first step is to find a TV channel that isn't being used in your general vicinity. Although after the 2009 DTV transition in June a lot of "whitespace"(i.e. unused television bandwidth) became available, most of this whitespace is still legally dubious and many of these channels are still tied to the original owners via legal identity and copyright. However, because of this legal ambiguity a lot of free space is still up for the taking.
The best option for finding free space is the FCC's own search engine for these things:
http://fjallfoss.fcc.gov/prod/cdbs/pubacc/prod/sta_sear.htm
Simply type in the channel (try a range of 14 to 35) and your state, along with the type of broadcasts available. Try to avoid channels that correspond to channels in your area (i.e. CBS 2 in New York). While they might be free because of the DTV transition and broadcasting in a higher channel range, they are still virtually broadcasting through that channel and might also have dibs on it for visual identity's sake.
100 comments
1-40 of 100next »
Apr 10, 2012. 9:08 AMblkhawk says:
Your project should be classified under Technology→Wireless.
Jan 24, 2012. 11:33 AMearthwindwater says:
Nice write up. But, there is a much more simpler way. You can build your own channel with a Roku box. They are under $100 bucks. I got my channel up and running in a weekend. Just fyi...
Mar 22, 2012. 10:01 AMBtRanbo says:
how does it work. im keen, will evry1 that owns Roku be able to watch my channel. does Roku works outside US and UK?
Feb 13, 2012. 6:04 PMjohnnyme33 says:
HOW!! D:
Feb 20, 2010. 12:23 PMdrbill says:
Got a VCR that works?
Got an old antenna amp that works?
Got a good TV antenna on the roof?
Fine!
Hook the antenna amp so that its input is fed from the output on the VCR.
The VCR IS a transmitter.
The antenna amp amplifies VCR output and feeds that signal to the antenna on the roof.
The antenna on the roof is a tuned yagi beam antenna just as it sits.
Hook it all up.
Put tape of some movie in the VCR turn it on and play it.
Your on the air.
Point the antenna in the direction of a lot of other roof top antennas and, bingo, someone is going to receive your signal.
Mar 22, 2012. 9:43 AMBtRanbo says:
Finally a good and simple advice. thanks mate
Aug 4, 2011. 3:07 PMwb7ptr says:
Cool! Don't get in trouble though :)
Feb 13, 2012. 6:07 PMjohnnyme33 says:
uhh... and how often are people caught? i rly dont like jail
Mar 7, 2011. 7:19 AMmajcherek128 says:
You can even do it with a VCR. But you will need a proper amplification, to get anything useful out of it.
Nov 27, 2011. 11:35 AMdrbill says:
Just need an antenna amplifier placed in circuit backwards so it pulls the signal out of the VCR and pushes it to the TV antenna.
Aug 4, 2011. 2:35 PMwb7ptr says:
Most certainly can. That is RF coming out of the RF Out jack, usually on channel 3 or 4 analog ...
Sep 12, 2009. 2:22 PMNirgal38 says:
Here in the US, the FCC has absolutely no sense of humor if they think you're violating their regulations. As a ham radio operator, I read their enforcement actions on a regular basis so if you're keen on paying $25000 fines or jail time, go ahead with this. Be REALLY sure that you're in the right because even if you win your case if the FCC decides to prosecute, you'll be out thousands of dollars in legal fees, etc. They especially frown on unlicensed broadcasters using the airwaves.
Aug 4, 2011. 2:43 PMwb7ptr says:
... and the worst of it ... they'll CONFISCATE your nice little TV station!
Nov 27, 2011. 11:28 AMdrbill says:
And anything else they think went into making it.
Dec 19, 2010. 10:10 AMemerson.john says:
At last. Another adult.
Sep 27, 2009. 3:10 PMaustinburke. says:
party pooper.
Sep 29, 2009. 7:11 PMNirgal38 says:
Hey, I didn't tell people not to do this. I just warned of the potential consequences if they do. If a person really wanted to do this legally, he could go out, get a Technician Class Amateur Radio Operator's license then can transmit using amateur TV and be perfectly legal. They'd still have to follow FCC regulations regarding amateur transmissions. Our local ham club just had a 6 year old pass the test so it's not that tough.
Oct 9, 2011. 7:24 PMstatic says:
Yes, but the moment an Amateur radio operator in the US starts to broadcast content of interest to the general public, they are in violation of Part 97. Most reading this instructable are interest in broadcasting content to the general public not to the niche of amateur radio operators. Yes the test is not that tough, I suggest you take the test before stating what's perfectly legal.
Oct 10, 2011. 3:45 AMNirgal38 says:
Amateur extra class license here. And I wasn't talking about general interest broadcasting. I was simply talking about what it would take to transmit an amateur TV signal legally.
Jan 29, 2011. 3:46 AMcivicturbo says:
Nice instructable! I have a idea for a transmitter. Howabout a frequency adjustable RF modulator. http://www.google.com/#sclient=psy&hl=en&safe=off&q=channel+vision+rf+modulator&aq=0&aqi=g1g-v4&aql=&oq=&pbx=1&fp=cd4bd38bf506aaa7
They come in 1 to 4 channel versions for home use and you can change your channels easy. They usually work on 14-69 off air or the cable range. Now the signal is low so you need to amp it up. You can start small and cheap and use a 20db cable/antenna amp then connect this to an antenna, either a TV antenna or something with better gain made for TV broadcasting. I did somthing like this for a workout room in a central building for a planned master community but for FM. The goal was to send the tv sound out for people exercising and wearing fm radios like they do in health clubs.
We had a rack mount high quality RF mod and a fm antenna (31" of bare wire connected to thecenter conductor of coax from the Mod.)
Problem was it had 4 feet of range. So I turned the gain output wide open, then sent this to a common 10db tv amp, then into a 15db tv amp, then a 20db amp. now thats some gain! Now finally the signal was strong all over the lower floor, no static. The suprise was as I drove away in the work van could receive the station up to two blocks away! and the antenna was in the lower level of the building!
I believe thre sucesses here was a little luck and the fact that that tv amps were of good enoght quality that the signal didn't cause the next one to clip its input or output. I think you can try the same with the TV RF mod to get some range around your neigborhood.
Oct 26, 2011. 2:11 AMsschoemann says:
Those that operate in the cable range will get you taken down real fast. You see as long as it stayed inside the coax it was cable TV. BUT outside that Coax those are Ham Radio frequencies and you will promptly run a foul of the law. We use those frquencies for Amateur TV nation wide...
Nov 27, 2011. 11:23 AMdrbill says:
Thank You ! I wanted to say this too and add that the FCC Fines are Hefty and the FCC is not backing down anymore because you have an inability to pay.
Oct 9, 2011. 8:01 PMstatic says:
Much has been made about being a license amateur operator somehow means you can legally broadcast content of interest to the general public. Sorry to tell you that Part 97 doesn't not permit US amateur radio operators to broadcast content to the general public. Broadcast content that's intended to serve other amateur radio operators all you want. In the event some members of the public may watch is not a problem.
Aug 4, 2011. 3:02 PMwb7ptr says:
Here's the FCC thing specifically on low powered TV:
http://www.fcc.gov/guides/low-power-television-lptv-service
Aug 4, 2011. 2:52 PMwb7ptr says:
http://www.fcc.gov/guides/how-apply-radio-or-television-broadcast-station
This is a description of the licensing required for transmitters by the FCC. I know most of you don't care but just in case there are some who do. You'll note that there is one category for very low powered stations for communities. Check it out before risking the 25,000 dollar fine/5 years or more in prison for operating without a license. Like I said earlier, I'm not into snitching on people .. but just know what you're getting into before doing it.
Personally, I do favor unlicensed operating in ONE case: extreme disaster and emergency scenarios. This is a case where ALL of the communications are down and the only way to get word out is to transmit (licensed or not!) on any radio you can get your hands on to let people know you're in danger ....
Right after Hurricane Katrina, a certain relief group here in New Orleans set up such a station. There were actually several pirate stations in operation, broadcasting such information as where to find food and water, medical care (there were street medics here before FEMA, etc. showed up ... I've been here since 10 DAYS after Katrina hit), and so on. So piracy DOES have it's place at times. What about Nazi Germany when they tried to take over the media? But as a general rule, I stay within the law!
Sep 29, 2009. 7:21 PMNirgal38 says:
A common recreational activity in ham radio is called "fox hunting." A transmitter is set up in an undisclosed location then amateurs triangulate on it using relatively easy to build equipment (homebrew directional antennas). Generally, the "fox" is found within a couple of hours.
It only takes one interference complaint for the FCC to bring their nice, professionally assembled equipment into an area and nail down the offender in a matter of minutes.
Hefty fines are no laughing matter. Jail time is no laughing matter.
Getting a Tech license here in the US is easy. You take a 35 question test and you can miss as many as 9. Look on the ARRL website (http://www.arrl.org) to find out if there are classes and/or testing near you.
You can also take practice tests at http://www.aa9pw.com.
If I can do it, how tough can it be? :)
Aug 4, 2011. 2:42 PMwb7ptr says:
I have had a tech plus license since the 1970's and have no intention of violating the law with my radios, but this site is interesting reading! Hams will often HELP in hunting down pirates (which they call "bootleggers"), especialy if the pirate frequency they choose is within the amateur bands!
I've seen the FCC at work twice, and they have some REALLY high tech equipment which makes ours look like it's out of the stone age ... so you pirates out there ... beware :) I don't "narc" on people ... unless it interferes with ham radio or emergency services but there are plenty of folks who will ...
Jan 4, 2011. 5:33 PMWhiteTigerTails says:
Heh, another way is to use a remote transmitter. A little 100 dollar netbook, and some inginuity, and you're set, and safe.
Think outside the box, people.
Not saying that you shouldn't take the test...
Dec 16, 2010. 12:09 PMSilentScreamer says:
I got 20/35 and I know nothing about radio transmissions :P
Oct 9, 2011. 7:30 PMstatic says:
Respectfully that's know ones fault but your own.` Amateur radio is about self study, and the ability to experiment with radio communications.
Dec 17, 2010. 1:52 PMNirgal38 says:
Keep practicing and find a local group that does testing and you can be a licensed ham radio operator just that easily!
Today's ham radio uses a lot of digital modes for talking, transmitting pictures and so on. It's definitely not your father's ham radio.
Dec 24, 2010. 10:10 AMSilentScreamer says:
I'm in the UK anyway so the american test isn't much use anyway. I do quite a lot with electronics though at the moment I don't have the time to get into ham radio and inadvertently lose even more time to hobbies :P
Jan 9, 2011. 10:28 AMNirgal38 says:
I chat with UK contacts so there is an organization that handles amateur radio in the UK and other European countries.
The tests aren't that difficult and help to keep the limited bandwidth clear of garbage chatter, interference and other annoyances.
Please, take the time to test. I don't know what the fines are like in the UK but I've seen fines of up to $25,000 levied here in the US and it's not a question of if they'll find you but when. Knowing UK TV licensing fees and the like, the BBC probably won't take kindly to unlicensed interference on their part of the radio spectrum.
Keep it legal, folks.
Feb 8, 2011. 6:23 PMcoppeis says:
Is this illegal?
Aug 4, 2011. 2:38 PMwb7ptr says:
QUITE Illegal .... if you're gonna do it, be prepared to get a visit from the Feds if they figure out who you are. I am personally NOT involved in pirate broadcasting but know a great deal about radio. Licenses are required from the Federal Communications Commission for most radio transmitters in this country. They govern radio, tv and a number of other broadcasting services ...
Aug 4, 2011. 2:34 PMwb7ptr says:
Hi TV Pirates. For those of you who do NOT wish to violate the law, check into the community broadcasting service. This is LOW powered TV and Radio, aimed at broadcasting to a small area like a neighborhood.
Here is a Wikipedia article on the subject. I can't remember whether a FCC license is required or not, but I'd check before going on the air. Most transmitters over 100mW require a license ...
http://en.wikipedia.org/wiki/Community_radio
May 29, 2011. 6:22 AMTheDutchOwner says:
In Holland, the Minister of Economical Businesses decided to make use the 800-MHz bands for Mobile communication, so it might be harder to do it here.
Mar 8, 2011. 4:55 PMyambobsven says:
what? naw I dont think my old tube made as good a pic as my hd
Mar 7, 2011. 1:18 AMlukeford says:
there is also this site i havent had a good look but i think it is ok
http://www.pcs-electronics.com/tv-transmitters-c-101.html?osCsid=b31b315ef4ffe54c5c68af85002fa5b5
Jan 29, 2011. 3:55 AMcivicturbo says:
I forgot to mention the quality tv amps we used are what System Intergrators use, Custom Home Theater install companies we're also called. Channel Vision, View Sonic, Regal all make good stuff, Radioshack and anything you get at retail; walmart, home depot, ect... I hate to say is NOT good quality. Cheap components inside, lots of noise, not flexable. But LOTS of profit margin thats why they are half to 3/4 the price of a good amp when they should be 1/10th the price. NO exageration, open one up some time, Scary!
1-40 of 100next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:splnlss(joncohrs)
I teach, work on art projects, and master music. For more info on me go to http://joncohrs.com or for more projects go to http://splnlss.com for audio go to http://spleenlessmastering.com thx!! Feel f...
more »
