loading
loading
How To Secure Your Water Heater Against an Earthquake
Featured
Picture of How To Secure Your Water Heater Against an Earthquake
If you live in an earthquake prone area, you need to strap down and secure your water heater so it won't fall over during a tremor. Here's how I secured mine; while you won't be able to replicate my setup exactly, hopefully this will inspire you to install, upgrade, or at least check and confirm that yours is safe.
Step 1: What an earthquake can do
Most water heaters I've seen are held in place by their own weight and, perhaps, the water connections. In earthquake prone areas that's not enough. Think of shaking a table with a tall glass of water sitting on it, or check out these movies of simulated earthquakes:
http://seismo.berkeley.edu/~rallen/seishaz/buildings/CUREEtest/
http://seismo.berkeley.edu/~rallen/seishaz/buildings/CUREEtest/officedinning.mpeg
See how the water heater just falls over?
You might be thinking that if there's a strong enough earthquake to tip over my water heater, I've probably got bigger issues. Perhaps true, but I don't want to add fire from broken gas lines and flood from broken water lines into the mix.
You'll note in the pictures, I've already installed a flexible gas line, and semi-flexible water lines. The water lines are ribbed copper pipes that have some flex to them.
Step 2: Get a strapping kit
Picture of Get a strapping kit
When we moved in, the home inspector pointed out that the water heater wasn't properly strapped down and suggested that correcting it be made a condition of the sale. The previous owners just bought a strapping kit, left it on the water heater, and called it good. I'm actually glad they didn't do it, because they probably would have done a bad job.
Here's the kit: It's essentially some metal straps and fittings.
Step 3: Plan
Picture of Plan
My water heater is located in a corner, so I decided to attach the straps on perpendicular walls and snug the water heater into the corner.
Step 4: Mount the straps
Picture of Mount the straps
One of the walls is concrete and the other is drywall on studs. On the concrete wall, I hammer-drilled and install concrete anchors. On the stud wall, I pre-drilled and installed lag screws.
zachninme8 years ago
Sorry I'm commenting so late, but... Doesn't it seem that putting that support back there would not help? After all, in an earthquake, you'd rather have it fall slightly backward, where nothing would break (Due to flexible pipes), than for it to fall forward?
When properly secured, the water heater should not move at all relative to the wall when pushed by hand. Any slack in the straps will allow it to accelerate during a quake, possibly tearing the screws out of the wall
ewilhelm (author)  zachninme7 years ago
The intention is that the water heater will not fall at all. The metal straps brace it into the corner against the back support.
Derin4 years ago
OMG LAG (screw)
DrStoooopid6 years ago
also, adding rubber feet to the bottom of the water heater would help with the shock....something not quite as hard as a hockey puck, but not nearly as soft as foam rubber. Maybe urethane bushing material
As an added bonus, keeping your water heater secure in an earthquake solves the pesky "two weeks of fresh, drinkable water" dilemna in your earthquake preparedness kit. Provided you can get to the heater, you can tap it for a secure source of potable water after a quake.
mje8 years ago
I see you're using flexible water and gas connectors- you might want to add a mention of that in your instructable.
ewilhelm (author)  mje8 years ago
Step 1 already mentions the flexible gas line, but I'll also note the water lines.
Brennn108 years ago
Nice job! Great thinking because you are in California! Here in PA, earthquakes are as rare as elephants!
yes because every day i too worry about my water heater being knocked over by an earthquake... lol anyway nice instructable...and what happened to that keyboard?
HamO8 years ago
Very well done. Great pix and a relevant instructable. Good job!
