How To: Sew Mitered Corners
686
26
Posted
Introduction: How To: Sew Mitered Corners
If you want to make your cloth napkins, table runners, etc. look more professional; try your hand at mitered corners. It's easier than you may think.
Step 1: Here's What You Need:
- Basic sewing knowledge.
- Sewing Machine.
- Fabric Scissors.
- Fabric for your project (napkin, table runner, or anything that has overlapping corners). I am working on a table runner.
- Thread.
- Iron and surface to iron on.
- Pins (optional). I don't use pins very much, but if you are used to sewing with pins: then have enough pins to pin your fabric along the way as you normally would.
Step 2: Fold + Press
Start with your fabric wrong side up. Fold up your fabric hem on both sides (see photo above). Usually you would fold the hem 1/2 inch twice for a 1 inch seam allowance, or 1/4 inch twice for 1/2 inch seam allowance.
Press the fabric with your iron so there is a nice crease.
Step 3: Unfold + Cut
Unfold the seams. Notice the creases. Starting at the top corner of your fabric and going down there are 2 intersections. You can mark these for easier reference, but it is not necessary. Fold the corner down so the first intersection is over the second intersection. The crease lines should match up. Cut off the corner straight across the first intersection.
Step 4: Fold + Sew
Fold over your edges again, the same way you did in the first step. Your corner should look like the first photo here. You can either stick a pin in it to hold, if you wish, or press again with the iron, then repeat on all four corners. Once you have all the corners done, stitch along the edges all the way around and you're done!
Now, step back and admire your work!
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
