loading
Step 4: And now to smooth it all out!
You look done, but here's where you get smooth. Really smooth, and bumpless. Remember which direction the grain of your hair went, and how you shaved along with it? Changeup. Now we're going to go across. If you shaved down, shave to the side. If you shaved to the side, shave up or down. Absolutely don't go against the grain. You'll be smooth, but you're dooming yourself to a week of ugly red dots, especially around the chin. Go over it all with the razor across the grain, careful now, it's a bit different than last time. You might notice that the razor gets less clogged, but still keep it rinsed.
Done? Might not be. Run your hand over your face, check for rough spots. Go over those again before moving on to the next step. You oughta be very smooth by now.
Random Note: Yes I know I'm bleeding a little. I didn't cut myself, it's a zit. The aftershave in the next step takes care of cuts, anyway.
<p>Well, I'm going through breakup trauma and don't feel like doing anything. But sometimes out of boredom I surf internet and read posts. I've been following your page and I really liked it. After reading this amazing post of yours I feel inclined to shave my beard which has become a bush.</p><p>I followed your tips and some home remedies from this pos <a href="http://goo.gl/iwl5mV" rel="nofollow">http://goo.gl/iwl5mV</a> to get rid of those ugly and painful razor bumps. And now I'm all ready to court a new girl with my new clean shaven look. </p>
<p>Shaving but NOT ELECTRIC ?????<br><br>The author of this seems to be unaware that razors, which are in <br>essence, naked blades on a plastic stick - are not the same or as smooth as electric personal shavers.</p><p>There is a big difference between an electric personal <br>shaver with blades that do not touch the skin, and a safety razor or straight <br>edge razor which both scrape away the protective outer of skin, the epidermis. <br>These wet blade razors remove unwanted hairs but also this layer of skin and also its <br>precious natural skin oils. Then later on, you pay big money to replace with <br>artificial oils in moisturizers, shaving balm, bump fighters and shaving cremes to combat dry irritated skin which are CAUSED by razor blade shaving.</p><p>Too few people understand that the electric shaver with a well designed shaving foil or screen, can shave as close if not closer than a blade, as the foil lifts the hairs a fraction before cutting them. There are none of the ill effects of using a traditional safety razor e.g. nicks, cuts, ingrown hairs or skin darkening.</p><p>Electric personal shavers save time and money and crucially these days - water <br>and energy. The shaver blades are self sharpening and only need to be replaced <br>every 12 months or so.</p><p>There are many good personal electric shavers to choose from, which are <br>quite different from the male face and beard shaver. Use &quot;personal shaver&quot; as a <br>search term or something similar, to see the various offers. Check also that <br>the foil holes are graduated in size to accommodate the different hair types and <br>textures. Don't buy one where all the foil holes are the same size.You should <br>not need to pay more than $50.00. </p><p>http://www.bestbodyshaver.com/blog.asp</p>
<p>great tips! what about exfoliating? do men get exfoliation like women do?</p>
Men should see this and learn how to shave and not cut them selves
Informative tips above shaving. thanks
<a href="http://best-of-razor-bumps.blogspot.com/2013/07/how-to-get-rid-of-razor-bumps.html" rel="nofollow">How to get rid of razor bumps</a> is a big question that I HATE! i have a tool that can get rid of them FAST coming out soon. <br>Razor bumps occur when a newly shorn hairs grows back to re-enter the skin. As it continues to pierce and embed itself into the skin, a bump will appear as a sign of injury. <br>To get rid of razor bumps rapidly, save the part free of sweat and germs. Wash the regarded area with antibacterial cleanser. Development of bacterium can exacerbate the precondition and prevents skin&rsquo;s power to reclaim the bumps. <br>
I think that the most important thing to prevent rash and bumps is to disinfect immediately after shaving, and to keep the skin scrupulously clean whilst it is still tender. <br>I usually use the cheapest aftershave I can find, and lots of it. However, I have recently found Savlon Wound Wash spray which works just as well, doesn't sting, and doesn't make you smell like a big tart. <br>If you disinfect and then wipe your face with a towel....you've just reapplied a layer of germs. Disinfect again. About 10 minutes after you've finished shaving I think the danger has passed. <br>I used to suffer from awful razor burn, but since doing this it is a distant memory. <br>By the way - this applies to wet or electric shaves!
I agree on disinfecting the skin immediately after shaving. I use hand sanitizer and have had good results with it. I also use an antique safety razor that uses the double sided razor blades (I fancy myself a bit of a renaissance man ;) and it also minimizes waste). After using the razor and leaning my face, I swish the razor's head in a small tupperware-ish bowl of 90% isopropyl alcohol. This cleans the blade of any shin oils, dead cells and remaining whiskers after the water rinse. It also helps shed the water and any minerals it may contain to keep the blade sharp longer.
SKIN oils.... sheesh Hoopajoo, it pays to proof-read!
I wear a beard, so I only have to shave my cheeks and neck. I used a rotary electric for years, but never really felt that it was that close, especially in the days when we had to wear shirts and ties. A bladed razor is MUCH better and the shave is longer lasting. <br><br>For years now I've shaved in the shower with a disposable razor. I shampoo, wash all over with soap, then turn to the suction-cup mirror on the shower wall, lather up with soap, shave, then rinse everything starting with the hair and work my way down. <br><br>The benefits of this is that the time I've spent in the shower doing all of the preliminaries allows the warm water and moist air to soften my beard. It's less messy, I don't have to worry about cleaning the sink and I NEVER have to worry about errant stubble that makes its way into a shirt collar.<br><br>I buy the Gillette twin-edge disposables in the 52-pack from Costco. They're relatively cheap, I change them once a week or so and Gilette ins't making a mint off me. <br><br>Good instructable.
&nbsp;Thanks for this, I'm a female but I still took some advice from this tutorial. 5 years of shaving my legs and not once has anyone ever suggested going WITH the grain. (all Ladies razor directions say to go &quot;against&quot;)
It really depends on how your skin reacts to it.<br><br>If you go with the grain, the cut won't be as close to the skin.<br>However if you go against the grain on the first pass, it will irritate the skin.<br><br>Now if you do it a couple times with the grain and do the last shave against the grain, the result will be a much smoother shave. That is what I do and I don't get any ingrown hair from that. It just might not work for you.<br><br>There's a lot of little tricks that might work but most of all, it's good to use the proper shaving products, most women I know just use soap or bathing gel and it doesn't work nearly as good.
I have no need to shave my face..........not many women do, but i enjoyed your instructable anyway. i feel like you really got into the teaching part. You did good. Thumbs up.
If you really wanna get a close great shave, check out my instructable @ <br>https://www.instructables.com/id/So-you-want-an-old-fashioned-double-edged-safety-r/
Closest shave of all? Shave twice.
see thats where I get my burn, If I shave more than once every 2 or 3 days, I get burn
I think electric razors aren't to be discounted.<br/><br/>Sure, an electric razor is a totally different beast, but I've been using one for the last two years to good effect.<br/><br/>When I use(d) a disposable razor, right after hopping out of the shower in the morning I would apply some cream and shave. I find the electric razor works most effectively and painlessly on dry skin, i.e. <em>before</em> I shower. Even though I knew how to shave as you tell everybody here, I'd still get nicked on a regular basis with disposables. There's a rough patch on my throat that would always get scraped raw and bloody from just one or two passes of a disposable razor.<br/><br/>I don't have any such problem with my electric. The drawbacks are lack of precision, and it doesn't shave quite as close. Neither of them is a very big deal to me, since I've grown a circle beard and bought a precision trimmer to groom it, and my growth isn't thick enough to give me a bad 5 o'clock shadow.<br/>
aaahhh, barbasol. i remember years ago my dad would use that, and i would sneak into the bathroom when he was done and shave. i hate all this gel crap they have. i miss straight cream.
me too (hate gel). i use cream still.
tell me about, gel sucks! it burns my skin.
Good job. The only addition I want to make is you say to wipe your face when done. We see that a lot in television and movies, but if someone has sensitive skin, simply wiping off the lather residue might cause itching later on. Use lots of water. I use hot water first (fill the sink to half full) and then cold. I also rub all my skin with tea tree oil which smells nice and is a good antiseptic. Thanks!
I saw this and just had to laugh. but you have so many good tips... i loved IT!
Haha, I'm glad to be of help!
The last picture of step five is the best! Ha Ha!
I suggest that you now move on to the double edge straight razor. Muwhahahahahahah!
Okay, I am still new to the instructables thing, and actually haven't contributed yet (I know.. I'm worthless), but this is, thus far, the funniest instructable yet while remaining informative. Being of the girlish gender, I don't, as of yet (there is still a random chance I won't be able to say this one day), have facial hair but I think I will try going with, then across the grain of the five o'clock shadow I get on my legs! Maybe it'll hurt less.
hahahaha<br/>my girlfriend shaved my legs once when i was 16<br/>not even two year ago in fact<br/>funniest thing EVER<br/>clogged up her &quot;Venus&quot; shaver so many times she got annoyed<br/>then once finally done<br/>(pictures taken and since &quot;lost&quot; =p )<br/>a day later she was complaining of the stubble on my legs<br/>funniest<br/>thing<br/>EVER<br/><br/>
LOL, the only thing I have to say about leg stubble is... you don't have to kiss legs. When my dad decided I was old enough to shave my legs he says to me: "I'm tired of looking at your hairy legs." I nearly froze to death because it took SO long and had to throw the razor away when i was done. Oh and I tried the across the grain, then with thing. Didn't work for mah legs. The best thing ever (EVER) is to get goosebumps then shave the goosbumps! That makes for darn smooth legs (smoothest EVER), but can you get goosebumps on your face?
hmm<br/>i dont Think you can<br/>i never can except slightly raised hairs where my sideburns would be<br/>if the rest of the hairs on my face are effected<br/>its not noticeable<br/>gutted<br/>=p<br/>good idea though <br/>maybe you should do a leg shaving instructable?<br/>if its so hard / different<br/>i dont know<br/>just thinking as this instructable helped me realised why i kept getting ingrown hairs on ma chin<br/><br/>although ive only ever got razor burn from using an electric shaver<br/>which i will never use again<br/><br/>but meh<br/>just an idea <sup>+</sup><br/>trying to get more instructables out there to the world!<br/>
A WW II vet I use to work with sometime recounted how some of the "Mexicans" he served with used a plain old double edged blade with their hands , no metal handle to shave. BTW he wasn't using, Mexican in a pejorative manner, he seemed to speaking in awe of their skill.
Wow, I'll bet that was hard to do without cutting up your face.
This is a fairly good tutorial, but a better one is found on... myspace?!<br/><br/><a rel="nofollow" href="http://vids.myspace.com/index.cfm?fuseaction=vids.individual&amp;videoid=16546909">http://vids.myspace.com/index.cfm?fuseaction=vids.individual&amp;videoid=16546909</a><br/><br/>I use this method, and shave against the grain. I have not once gotten razorbumps using this method, and my skin is healthier!<br/>
I thought that was not so great. Some vague pseudo-science about pores CLINGING to hairs and some of the things mentioned here... but generally very lacking in actual helpful information. I'd say skip it.
Always use cold water, hot water softens hair but softens skin even more so make the contrast greater increasing risk of cuts, use shower oil not any soap as oil is not rinsed away like soap when shaving, rinse in cold water help prevent shaving rash.Does not close pores as mentioned above , pore are incapable of any movement.Finaly apply a small amount of germolene or similar antiseptic cream on morning and evening following shave for smooth trouble free shave.
I've never heard of shower oil, what is that?
Shower oil is soap free shower gel for people allergic to soap.
i shave my head and use the oil "shave secret" it costs $3 at walmart
<div style="margin-left:15px;"> <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/LIifh6aHsQM"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/LIifh6aHsQM" type="application/x-shockwave-flash" width="425" height="344" wmode="transparent"></embed></object></div>Now I know how to shave right! thank you!<br/>
I'm sure I missed an obvious line or something, but what exactly prevents bumps? I get bumps on my legs, but obviously I don't use aftershave on my legs (do any women?); is the aftershave the magical catalyst?
The magic is in the direction of the shaving. First pass is with the grain, second is across it. Many people shave the second pass against the grain, and this tends to cause ingrown hairs, aka razorbumps. I wish you luck on this, but I'm not sure 100% sure about shaving legs. I'm starting to think it might be worth finding a lady on this site willing to collaborate with me and provide some tips for the women. I like the site, but not enough to experiment on my manly thick leg hair.
Yeah, I'm thinking the magic IS in the direction. When you first shave with, then against, the grain, it seems like you're shaving that hair to the point where the nub retracts into the pore from whence it came, where it may possibly become a speedbump in the near future. When you shave with then *across* the grain, I can imagine that there would be just enough length left to the hair to keep it's growth path pointed out of the pore instead of elsewhere, avoiding the razor-bump problem.<br/>
You're exactly right! Though it also does help to make sure your face is very clean after a fresh shave, preventing any little infections that might turn into bumps as well.
Thanks for this, i tend to get alot of bumps and i wondered why.
Thank you, I like this instructable. Though I grew up with a father, he never had much use for shaving (because facial hair covers up scars like u wouldn't believe) but I like to keep some of it smooth, right? But I taught myself to shave. Now I'm 30 years old and I still can not shave without cutting or razor-burning myself, no matter how hard I try not to. I'm going to give your method a good hwhack.
thanks, this helped me learn how to shave, which I really needed
Some good tips presented, however I solved my razor-bump problem by throwing out my razor in 1977 ;-)
Putting on the shaving cream against the grain of the hair will help to get a closer shave. Though it is much tougher for people with curly hair to avoid razor bumps, especially around the jawline since hair will usualy change directions there. Brut 33 way better than Old Spice. ; P
This was great! Although not specifically relevant to me, i think it was well written and quite humorous, and just thought i should express my opinion :) kudos!
the key to a good shave has been around for decades--a good lather created with a badger hair brush shaved with a good DE blade--the razors have not been made in the US by Gillette for a long time but can be purchased--try the site: www.shavemyface.com for lots of good info--lakeroamer
About This Instructable
441,515views
82favorites
License:
More by SteamKit:How To Shave Without Getting Razor Bumps
Add instructable to:
