How To: Slush Drink Maker
3,904
16
Posted
Introduction: How To: Slush Drink Maker
Step 1: You Will Need
A small rounded piece with a a hole in the middle the same size as the motor drive(like the one shown in the picture) a pair of scissors, a glue gun, a motor, battery pack, some wire, a stand for the glass and motor, a container for the battery, two metal meccano piece with eleven holes(you don't have to use meccano you can cut some wood or metal I just had it lying around), a meccano three by for piece, a piece to connect the motor to the meccano (it's the orange piece) two L shaped meccano pieces that have a total of three holes, two L shaped pieces with a total of two holes, eleven nuts and bolts, a one kilogram weight, a drill a spanner and allen key/ screw driver (for the nuts and bolts), some spray paint (optional but it improves the finished look), a piece of meccano with seven holes in total two of which should be folded over the edge and some small heat proof packets
Step 2: Making the Stand
First you need to get the stand and drill two holes in its sides about fifteen centimetres apart (your stand should be around thirty centimetres around)
Step 3: Adding the Motor Brakcets
Get both of your eleven hole meccano pieces and bolt them to the stand straight with two of your nuts and bolts and your spanner and Allen key/screw driver
Step 4: Sticking in the Weight
Plug in you glue gun until its warm then get you kilogram weight and stick it onto the bottom of the stand (it will help later to stop it moving about
Step 5: The Motor Brackets Part Two
Get your two L shaped pieces with three holes and bolt them to your motor bracket
Step 6: Adding the Motor
Get your motor and connect it to you wires switch and batteries to make a circuit then bolt it to the motor brackets
Step 7: The Battery Holder
Get your battery holder and your scissors and cut a small slit for the wire
Step 8: Spray Painting the Battery Holder
Find a spot to spray paint then lay down some paper and spray it all over making sure it is now the colour you want it to be
Step 9:
A few coats later
Step 10: Adding the Stirrer
Get the piece that has seven holes two of which are folded and bolt it to the motor using you nuts and bolts
Step 11: Stirrer Step Two
Bold both of your two holed L shape pieces any where on the piece you added in the previous step making sure that they face the Same way
Step 12: Stirrer Step Three
Get your three by four piece and bolt it to the two L shaped pieces you just added
Step 13: Finishing Up
You have almost finished now all you need to do is put the heat proof bag and battery pack in the battery container
Step 14: How to Use
To use it its simple, you put a glass of your desired drink in a glass then put that on the platform so the stirrer is inside it then fill the bag with got water (so the batteries don't get cold when they do they run out quickly) and flick the switch to turn it on then put it in your freezer wait forty-five minutes to an hour and take it out, you will see it has turned to a slushy mixture
Step 15: If You Liked This Please Vote for It Thank
  • Gluten Free Challenge
  • Paper Contest 2018
    Paper Contest 2018
I hope you like it if you do please vote for it p.s you are awsome
