3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Solve A Rubik's Cube!
How To Solve A Rubik\
This instructable will teach YOU how to solve a Rubik's cube!
I will also teach you algorithms that will enable you to make your cube "pretty", which will impress people!
Note: This is only ONE algorithm, although it is applicable to ANY "situation" that can be presented to you on the cube.
Materials:
1 Rubik's Cube
1 Good Memory (if you want to impress people)
1 Sack Load of Patience
Subnote: This method took me 3 days to master, and a week to perfect, working on it about 4 hours a day. I can now solve a cube in under X3X X2.4X 1.37 minutes. (Look Below)
Step 1Getting it all messed up! (use when necessary)
Pretty much just scramble up the cube.
-Don't turn any one side more than twice in a row, then you're being inefficient.
-Don't turn two edge sides the same way, you could have just turned the middle section
-Don't turn only one or two faces, rotate the cube while scrambling to get a better scramble
-If you want the best scramble, scramble the middle rows and columns, that tends to make the solution take longer.
372 comments
1-40 of 372next »
Jan 12, 2012. 1:44 AMadamye says:
It's confusing... a video might make it easier to understand...
Dec 28, 2011. 3:12 AMAaqib1 says:
The instructions for right should be D' R' D R D F D' F'
Dec 7, 2010. 8:34 AMramnath says:
1yay i did it 23 seconds i solved it yaay almost in top
Aug 25, 2011. 4:06 PMrlemaitre says:
seriously how teach me i need to get it in under 1 min 30 seconds for school
Dec 20, 2011. 4:33 PMguitarmonk15 says:
2 look Fridrich... Google it
Dec 12, 2011. 9:11 PManicoletti says:
I'm stuck. Anybody know if there's a way to solve this without breaking it apart?
Oct 27, 2011. 3:48 PMrnolan6 says:
Took me a while but I got it. thanks!
This guy here has got to be the world's fastest in this video
http://www.youtube.com/watch?v=SZF6ZB-jAGQ
take a look
Oct 21, 2011. 11:34 AMmajorson says:
Really nice guide, had some trouble with step 8,
But managed to fully solve the Rubik's cube with this:
How to solve a Rubik's Cube Guide
majorson.
Sep 13, 2011. 1:25 AMgpearl says:
this is actually not the perfect way solving cube .....the writer has just tried to modify the original and described in his own method ... once you leanr to solve it you will have your own million ways of solving it ...
Jul 9, 2011. 11:00 PMkenz_benz says:
nope. dont get it....this thing makes me feel stupid. i have no idea what they're talking about -_-
:P
Jun 15, 2011. 6:46 PMjlower says:
I learned how to solve a rubix cube here: http://howtosolvearubixcube.blogspot.com/ Loved the video tutorial :D
Mar 8, 2011. 8:12 AMScottNRC says:
Struggled after step 8 - but managed to finally get there with some additional help from a video on the official Rubik's website though!:
http://www.rubiks.com/solving-center/
How some people do this in minutes is beyond me !
Feb 27, 2011. 8:39 PM2chanjae says:
Try to shuffle it after you do step 6.. I did it for 2weeks 2hours a day and finally could solve the cube...
Feb 27, 2011. 8:09 PM2chanjae says:
It's a bit confusing..
Jan 29, 2011. 12:03 PMwolfarkas says:
in the first picture, the arrows show you which algorithm you have to use. however, they are paired incorrectly.
Jan 29, 2011. 10:11 AMwolfarkas says:
I have a problem. all of my corners but two are in the correct spots facing the correct directions. these two are on non-consecutive corners. they are switched so that it looks like this:
what do i do?
Sep 19, 2010. 9:34 AMBlackonyx2234 says:
why is the white square in the center of the blue? or did i mess up somewhere?
Sep 18, 2010. 12:40 PMHaagenize says:
I'm not sure if you guys noticed, but step 5 is wrong
I've been following the steps, and on step 5, when turning to the right, one of the steps is wrong, its actually
D'R'DRDFD'F' instead of D'R'DRDFDF'
Sep 8, 2010. 1:03 PMRock$tar says:
ive been working a while on the rubik's cube also and i have gotten my time down to 50sec.im working on the 20 step process and going to go for the world record.
Apr 10, 2010. 7:56 AMfloryzzz says:
 I solved it in 1Minute and 40 seconds
And scrambling go the fastet as u do Ri U 10 times
then twist the cube that way the cubes left is front
Apr 10, 2010. 7:57 AMfloryzzz says:
PS.
And do it again
Oct 13, 2009. 7:00 AMkate_27 says:
 Thanks so much, I am finding this more helpful than ANY tut. so far! Ill let you know if I finish it!
Oct 13, 2009. 9:39 AMkate_27 says:
 I DID IT! Thanks Breezeonhold!
Aug 30, 2009. 10:11 PMsingabarat says:
I dont get a thing out of this tutorial.its all mixed up and unsenseible.
Aug 6, 2009. 6:08 AMhow-to-solve-rubix-cube says:
cool moves you can fiind more here: http://rubix-cube.110mb.com/
May 14, 2009. 12:26 PMHitmanSA says:
what you say man is too complicated.i don't even understand the moves.what's the difference between R and R' what does this ' mean?
Jul 15, 2009. 11:49 AMbman214 says:
' means inverted R means right 90 degrees CLOCKWISE R' means right 90 degrees COUNTER-CLOCKWISE You're Welcome What directions are M and E. Is M up and E right
Jul 9, 2009. 7:49 AMRayn3 says:
If the notation of the moves in confusing check out http://www.rubiks-cube-solution.com . It shows the moves with pictures and arrows. I love this Instructable though.
May 20, 2009. 1:22 PMsuzukisuv says:
I hope this will help me, i will train hard. I have see guy doing rubic cube on youtube with hes feet in 20 seconds. Is that possible.
Jun 8, 2009. 5:39 PMiPwnU718 says:
all he did was get the finished rubixs cube and messed it up with his feet and reversed the video
May 16, 2009. 1:46 PMvikings84 says:
To get this look, just turn the two outside columns up twice and turn 1/4 turn clockwise and continue until you get the wonderful checkers! then, just do the opposite to solve it... outside two columns turned down twice, 1/4 turn COUNTER-clockwise and continue until its solved! :)
May 16, 2009. 1:44 PMvikings84 says:
In order to get this look to the Cube, all you have to do is move the middle column (doesnt matter what color) up once and rotate the cube 1/4 turn clockwise until you get the centerpiece look to it. you can only do this when the cube is solve, by the way. anyways, to undo this, just pick a side, rotate the middle column DOWN and turn 1/4 turn COUNTER-clockwise until the cube is solved.
May 10, 2009. 9:36 AMlaofmoonster says:
There's an inaccuracy in the first cube example... compare to http://www.chessandpoker.com/rubiks-cube-solution.html step 5... it's slightly different
May 10, 2009. 9:41 AMlaofmoonster says:
Also, there's a step missing here, see step 6 from the same link
May 10, 2009. 8:47 AMlaofmoonster says:
This was confusing at first. The algorithm switches "1" with the "2" on the left, not the one on the right.
Apr 30, 2009. 10:11 AMgone-d says:
haha im in class looking this up while the teacher doesnt see because im sooo bored just playing wiht a cube in class
Apr 24, 2009. 8:38 PMTragety says:
My Record right now is about 47 seconds
Feb 11, 2009. 8:47 PMfearme36 says:
ok i understand everything except what does (') mean?
Apr 23, 2009. 9:41 AMfearme36 says:
oh duh... i'm so stupid. Thanks.
Apr 12, 2009. 7:23 PMmusicninja17 says:
Counterclockwise.
1-40 of 372next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
80
Author:T3h_Muffinator(olopede)
I'm a just a not-so-average human with a passion for making. I see a world of hackers, makers, and producers as the sun rises in the near future. I'm starting olopede, an educational electronics k...
more »
