Step 2Solving the top corners
-Pick your favorite color (I always use blue, some use white, it really doesn't matter)
-Locate one of the corners
-Make it so that your favorite color (we'll use blue from now on) is facing upwards and that the other two colors on the corner piece are on the side of the cube. (You can just rotate the cube so that the blue part is facing up)
-Rotate the cube so that the first blue piece you found is in the top-left hand corner
-Find another Blue corner piece, this time with one of the same "side colors" as the first one you picked (In my case red or white)
- Get your target (new) corner piece right under where you want it to go by rotating the bottom or side rows or columns, keeping the original piece in the top left hand corner, then follow the steps in the pictures until you have all four top corners solved!
As for notation, a capital letter by itself represents a 90 degrees clockwise turn if you were looking at the face itself.
For Example: U means turn the top layer 90 clockwise as if you were looking at it, or to the left.
L means turn " Left " " " " " " " " " " " , or down
R means turn " Right " " " " " " " , or up.
I've included some pictures that help explain all the moves.
(I need permission for the pictures first, so they'll be up by tomorrow, probably)
14
comments
Add Comment
Add Comment
