Step 7Orienting the Bottom Corners
For example, in the first picture you see that two of the corners are not green. That's because the green is on the side of the cube. We need the green to come to the top of the cube.
There are three cases for this step:
- There is only one corner piece with green on top. In this case, make sure that that corner piece is on your right, and closest to you, then preform the algorithm once ( first cube example in the first picture).
If all of the corners are solved, then continue onto the next step, otherwise see if you have the same or another case, and follow the instructions for that case.
- The are no corner pieces with green on top. In this case, follow the 3rd cube example in the first picture, making sure the cube is facing you the right way, and preform the algorithm.
- There is more than one corner piece with green on top. In this case, follow the 2nd cube example in the first picture, where there is a corner that is not green in the closer right hand corner, and any of the other corners are green. You MUST make sure that the right corner closest to you is NOT green.
Once you have solved all the corners, move onto the next step.
8
comments
Add Comment
Add Comment
