3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Solve A Rubik's Cube!
Step 8Positioning the 4 remaining middle pieces
Okay, so now all of the corners are in the right place and orientation.
You should have one side that has the right middle piece, but it doesn't have to be in the right orientation.
-If you do, then look at the cube from that side (the one with the correct middle piece between the two corners) and preform one of the two algorithms (don't look at the first picture, that's just for fun, look at the second picture)
You'll either need to shift the middle pieces one way or the other. Based on which way you need to go, right or left, do the appropriate algorithm on the 2nd picture.
-If you have more than one or none in the proper orientation, use the "scramble" algorithm on the 3rd picture, looking at any side when you do (so long as you don't rotate the cube up or down), then start this step over again
14 comments
Dec 12, 2011. 9:11 PManicoletti says:
I'm stuck. Anybody know if there's a way to solve this without breaking it apart?
Jan 29, 2011. 12:03 PMwolfarkas says:
in the first picture, the arrows show you which algorithm you have to use. however, they are paired incorrectly.
Feb 10, 2009. 7:10 AMchinchang says:
Now i have one side with just one green piece. Which algo do I apply now ? Plz reply...thanx
Feb 10, 2009. 10:58 PMchinchang says:
this is the situation . Rest all is in order..How to proceed now ?
Apr 12, 2009. 7:21 PMmusicninja17 says:
The only solution is that you have to pop that peice out and switch it. Someone has tampered with your cube. The mechanics of a normal rubics cube only allow peices to be flipped in pairs.
Mar 8, 2009. 11:07 AMmrmoneybagss says:
dude there is no solution someone must have taken the cube apart and switched that block thing
Feb 11, 2009. 7:17 AMchinchang says:
no...never. Before arriving at this situation I had solved the top & middle layer. then according to yr tutorial I should hv arrived at a pattern....but i didn't :( Suppose i used different algos to solve the top and middle layers, then wont yr steps work in dat case ?
Mar 1, 2009. 4:42 PMSkateRubiks says:
all you have to do is redo the algorithm for that part. and my record with the method is 49 seconds.
Mar 7, 2009. 2:17 PMnaissihrk says:
i cant solve the top layer ..im already done resolving the first to layers ..what will i do
Apr 16, 2008. 4:50 AMrazmitaz says:
I have the situation in the right where i need to move some of the blocks right but for some reason the algorithm isn't working I am doing it exactly as is written but i always end up with ont piece in the correct place but the others still need moving??
Apr 11, 2008. 3:56 PMrazmitaz says:
When I click the pictures below the big picture the page just reloads but the picture does not open. Why is this?
Mar 24, 2008. 2:45 PMardua says:
I made a mistake in my first comment (in the second sentence). Correction: If the 2nd picture is the SCRAMBLE algorithm then what is the first picture?
Mar 24, 2008. 2:43 PMardua says:
I got step 7,but i don't get this one. If the 2nd picture is the algorithm, then what is the first picture. I succeded in getting the fish pattern, but every time I did this, the side of my edge pieces were incorrect. What do I do?
Jan 23, 2008. 4:49 PMtbeacleay says:
i can't find '"scramble" algorithm on the 3rd picture' which step has that algorithm listed?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
80
Author:T3h_Muffinator(olopede)
I'm a just a not-so-average human with a passion for making. I see a world of hackers, makers, and producers as the sun rises in the near future. I'm starting olopede, an educational electronics k...
more »
