3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Speed Up Utorrent 1.8.1
This instructable is for people who want utorrent 1.8.1 to go faster. This will make utorrent go a few times faster.
--== Think ==--
Lets think, what can you do with all of that time saved?
Step 1Getting To The Preferences
1. Go to the toolbar at the top and click options.
2. The select Preferences
*shortcut* CTL + P
56 comments
1-40 of 56next »
Feb 1, 2012. 1:10 PMEverett_McKinley says:
The scheduler stuff is actually pretty helpful with seeding.
If you got file that you want to seed you can set it up so that U-torrent will open when you turn on your computer. then using this scheduler you can make it seed a different file each day. That way the seed faster then if they're all going at once. ;)
Jan 26, 2012. 7:57 AMmarius7ss says:
OH MY GOD THANKS
NOW I FOUND OUT IT WENT FROM 48 KB/S TO 1500 KB/S
TY SO MUCH
Jan 26, 2012. 7:55 AMmarius7ss says:
Thank you very much, even with my bad internet connection my rate went from
48 kb/s to 270+ !!
Apr 14, 2009. 5:22 PMsarahxwatson says:
Thank you so much :) I have a bunch of hard-to-find foreign films downloading that have been taking forever and your expertise helped me enjoy my movie night
Feb 7, 2011. 5:01 AMgoofyone says:
Hi using u torrent 1.8.5 on vista hp 32 bit so what new speedier settings might i try out - thanks . .
May 1, 2010. 6:44 AMGrissaOstDrauka says:
Does this work with uTorrent 2.0.1?
Mar 9, 2010. 2:28 AMEffigy Of Death says:
Can we make the maximum upload rate 1kb/s or is that not faster?
Oct 27, 2009. 12:00 PMwowannoying says:
my one went down by about 20% is it just me or od i have a lousy internet connection?
Oct 24, 2009. 9:12 PMMacG5User says:
 I Did exactly what you said ...... Look at he results, There great right......OH wait the green line is supposed to go the other way,  I think?
http://www.upload.mn/view/32ae3hu02g5gt3y66wgp.png
Oct 24, 2009. 8:57 PMMacG5User says:
 NO! that is illegal downloading, Unless there are deeds of free ....  xBox wii pc and movies
Jan 21, 2009. 3:23 PMbenjgvps says:
At least use a Linux ISO for testing than show the world that you are taking money away from hard working companies! Thanks for the UPnP trick, should have checked that.
Oct 24, 2009. 8:55 PMMacG5User says:
 I'm with /\
Oct 22, 2009. 11:24 AMJautsipau says:
10Kb/s increase YAY!
Sep 23, 2009. 7:09 PMdellababes says:
im not sure whats going on with my utorrent. i dont know 2 much about this sort of stuff. i did this and i think it may of worked a little bit but its still saying its going to take like a day to download a season.. but it's already been a day :(
Jan 21, 2009. 1:19 AMkarossii says:
There are many good guides out there for micro Torrent (uTorrent) as well as other bT programs... and one thing common to them all is the fact that you have to take a few steps customized to your specific machine. In other words, while this guide worked for you and your setup, it would slow down my machine because of my network and router settings. There is no single method for everyone... you should definitely mention that, and then research the proper way to help others set up uTorrent on their machine, instead of listing specific numbers to type that will yield poor results for a lot more people than it will help. Fix it; until then, this is a bad instructable. 0.5 stars.
Jan 21, 2009. 1:22 AMkarossii says:
Oh, and by the way - the settings you are recommending are basically leech only, and will in the end net slower speeds because of lack of seeding. A client with a Leech to Seed ration of 1.0 or less gets lower priority and won't download nearly as fast as one who has, say, a 4.2 or a 9.6 (random numbers). I have noticed as my seeding ratio has increased (I am now at an 11.4), my connections are solid on every single download, no matter how few seeders there are.
Jan 22, 2009. 6:03 PMjayhawker08 says:
not necessarily true. My share ratio is well below .1 (go ahead and preach to me) and it's not unusual for me to dl around 1mb/s although overall average is around 400 kb/s. I think it just depends on the files you're downloading
Jan 23, 2009. 8:43 AMkarossii says:
I'm not saying you cannot get good speeds with a low ratio. But with a high ratio, you ALWAYS get good speeds. I have gotten files with 5-10 seeders (or less) and 100+ leechers active. And I get full speed (8-12 mb/s) on those files now. In the past, when my share ratio as <1.0, or even up to about 2.5 or so, I would sit at a crawl on files like that for hours (sometimes days, even weeks), until either the number of leechers dropped, or the number of seeders increased, or both. Basically, the ay it works is that most P2P clients today will use that ratio to determine your priority. If you have been waiting 'in line' for hours to download a file and your ratio is low, someone else may come along with a higher ratio and walk right in front of you and get that bit you needed first. it doesn't mean you'll never get anything, or even that you'll always have bad speeds. It just means you don't get everything as quickly as you could - and as I said before that can make a difference of not only hours, but days and weeks.
Sep 24, 2009. 1:17 PMjam1478 says:
I never knew that, i should start seeding
Jan 21, 2009. 7:30 AMfrollard says:
Karossii has it right on the nose - if you have uPnP enabled, you should have randomize port turned on. Those settings may work for you, but my ISP is different from yours, and its all subjective and relative. Scheduling can be a very important thing, so saying 'DONT TUCH THOSE' is uninformative. Try explaining what each setting does vs. the infrastructure of a torrent, and people could learn from it...Such as karossii suggests; the server knows your seed ratio, and if its less than one, you get crap for packet offers from other peers.
Sep 8, 2009. 1:11 PMtommiesmee says:
instead of 2 days and 6 hours, it's gonna take me now 14 weeks and 2 days... are you sure where ain't something wrong in this Instructable?
Sep 9, 2009. 6:10 AMtommiesmee says:
of course, i downloaded utorrent 2 days ago at dat the official site (2 days before i posted)
Jul 23, 2009. 4:07 PMvenkatv15 says:
thanks .... u r great!!!
Jul 21, 2009. 7:35 AMzk111222 says:
my speed dropped by 20kb/s ???
May 13, 2009. 2:30 AMmastermakoko says:
uhhh......i dont understand? my default "speed while ratio "is 150% and you told me to turn it down to 100?
May 15, 2009. 3:41 AMmastermakoko says:
but.... no! now my speed is slowing? are you shure?
Jul 18, 2009. 1:50 AMmastermakoko says:
no its 1.8.2
1-40 of 56next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:mrmoneybagss
I am a guy who lives in California. During my spare time, I like to see if somebody posts a decent instructable that I would like to try. I also love to play xbox 360.
