Introduction: How to String 6 Diamond Mesh
This pocket demonstrates how to string 6 diamond mesh. 6 diamond is a great alternative to standard mesh, and is the most commonly used "monster mesh" in lacrosse. However, I would recommend this more towards a defenseman or a box lacrosse player, which is what I use 6 diamond for. Check this video out to see some tips from the best in the biz, Greg from East Coast Dyes.
Also check these other great instructables
https://www.instructables.com/id/ReplacingChanging-Lacrosse-Stick-Shooting-Strings/
https://www.instructables.com/id/How-To-String-A-Lacrosse-Head/
https://www.youtube.com/watch?v=ACgnYoBFXcc
Step 1: Gather Supplies
1 piece of 6 diamond mesh. 2 sidewall strings, about twice the length of your head 1 top string just a little smaller 1 bottom string How ever many shooting strings you prefer
Step 2: The Mesh
Stretch the mesh. I usually soak it in water as well
Step 3: Fold the Mesh
Find the first 5 diamond row and fold it on the the second 5 diamond row. You can use either side of the mesh but I prefer the side that is more rough feeling for extra hold.
Step 4: Topstring
Go up through the plastic and then continue up through the mesh. Loop backaround the sidewall hole and through the mesh.
Step 5: Topstring
Pull it tight
Step 6:
Go through the plastic then the mesh.
Step 7:
Then go up through the mesh then the plastic and down through the loop you created.
Step 8:
Finished Product.
Step 9:
Repeat, doing one loop in one mesh hole, then the adjacent mesh hole.
Step 10: Sidewall
Start by Pulling the string through Plastic then Mesh.
Step 11:
Skip a hole, go through the plastic then the mesh and pull back through the loop you created. Repeat down the next three sidewall holes.
Step 12:
Step 13:
Next, we will create the pocket. Go up through the mesh WITHOUT going in the plastic first. Then do a regular interlock as shown above. What this does is bunches the mesh up but it won't make the pocket too baggy. This step is crucial, some people do regular singles or double ups, not covered in this tutorial, but I believe they make the pocket far too baggy and undefined.
Step 14:
Step 15:
Finish the sidewall by doing interlocks the rest of the way down, then go IN through the mesh and OUT through the plastic. Tie it off and you're finished!
Step 16: Bottom String
This is critical to the pocket shape, and definition. Go up through the first hole.
Step 17:
Then you go back around and up through the plastic
Step 18:
Go through any of the last two 5 diamond rows on the second to middle mesh hole. Then go through the next, there should be one hole in between, symmetry is key. Then go up through the plastic and down the other end and your finished!
