How To Take Apart A Microwave
Taking apart microwaves can be dangerous, on this instructable I will show you how to take apart a microwave safely and explain the parts and what you can do with them...
I found this microwave (pictured) lying around in the streets, I took it home with me and took it apart, meanwhile, I decided to make an instructable so you can get an idea of how to take apart a microwave and what its parts can be used for.
Step 1What equipment you will need...
You will need tools to take apart a microwave, your bare hands won't work. :-)
  • A set of screw drivers with different shapes and sizes.
  • Wire cutters
  • Pliers
  • Alligator clip
  • Hammer (you don't need this unless something needs to be banged apart)
You might need other types of tools depending on the type of microwave you are going to take apart.
228 comments
1-40 of 228next »
Dec 16, 2011. 3:51 PMsolaralternatives says:
If you REALLY want to be safe, use a HEAVY bladed screwdriver (preferably one from a yardsale - cheap, and you don't care if the super-powerful electrical arc pits the metal!) then measure the voltage on the cap with a multimeter set on highest setting. Better to blow up a cheap meter (such as those sold @ harbor freight) than.. to die.
Jan 5, 2012. 11:40 AMdeaks says:
i've also heard it said that when one is in a tight spot (as this one looks to be) use two junk screwdrivers crossed so they are touching (hold one in each hand). that way, you don't have to get in at a right angle to the cap to touch it or get really close like with the alligator clips.
also, using two, if you are startled and drop them, they will always fall OFF of the cap. using a single screwdriver, you will occasionally weld the screwdriver to the cap you are discharging.
just some thoughts.
Nov 6, 2011. 6:22 AMVulnic says:
I'm still very concerned about discharging the capacitor. Would it make it any safer to use one of those wrist chords used when building/fiddling around inside a computer to clip onto something metal and ground you?? I mean it's not as if you get another shot at this if it goes wrong.... like they say 'There's not many DUMB electricians left in the world ... they're all dead"
Dec 29, 2008. 9:40 AMjoinaqd says:
oooh!!i know what u can do with them!!connect a lotta high voltage capacitors together and make over a thousand volts, then connect the capacitors wires to the timer since its a switch and set the timer and blow up stuff from far away..example a light bulb.. Reply back if by idea is nice..
Nov 3, 2011. 7:12 AMVulnic says:
Lol... yeah it sounds nice.. but also sounds dangerous. I like you're thinking though.
Apr 3, 2009. 7:14 PMTechNerd1012 says:
sounds plausible
May 11, 2009. 5:43 PMGamer917 says:
i think you're a Mythbusters fan
May 13, 2009. 2:32 PMTechNerd1012 says:
oh yes, definitely!
Jun 22, 2009. 6:08 AMDerin says:
BUSTED
Dec 30, 2010. 9:18 PMjupeter5 says:
ummm... you can use the magnetron to build a micro wave gun. basically it can also be used as an EMP device so it does have a use.
Sep 20, 2011. 1:15 AMszulli-randall says:
Do you think you can show me how? I want to make a Sonic Screwdriver with one of those inside it.
Aug 31, 2011. 5:42 PMriff raff says:
I believe those are "browning" tubes, to make your food more "grilled-like."
Apr 27, 2011. 10:50 AMsnateraar says:
Mind you, some parts of the casing of the magnetron itself like the pink-ish ring around the outlet may contain berrylium oxide which is not quite healthy.
It's safe as long as you don't inhale it though.
Aug 31, 2011. 3:27 PMriff raff says:
Yeah, as long as you don't scrap off the beryllium oxide and snort it, you should be okay.
Sep 15, 2009. 3:49 AMne171pro says:
Magnetron Hardly Any Use? I'm not trying be rude but your PDF here showed me how to take apart my microwave so I could get the magnetron. (not for its magnets) Anybody out here that can help wire up my magnetron. I'm really not stupid with electricity, I cant for the life of me get it to do what I'm seeing freaking 14 year olds do. I know its not broken components (have 3 taken apart microwaves.) Is it the ground wire you touch it with? Or is just some other wire not in the circuit. Man I'm so frustrated.
Aug 27, 2011. 2:51 PMhbell says:
Jesus christ dont power up the magnetron! the electromagnetic radiation could easily kill you, as could the transformer. If you cant wire up the transformer, how would you build an enclosure for the microwaves? Im not trying to offend you, but it sounds far too dangerous.
Aug 13, 2011. 9:18 PMstatic says:
A bit of additional info on the magnetron  This article gives detail on removing the magnets http://www.repairfaq.org/REPAIR/F_micfaq6.html#MICFAQ_021  Magnetrons contain materials than can be a health hazard if they are reduced to a size where they can enter the lungs, I don't have clue to the actual risk factor, just visit http://en.wikipedia.org/wiki/Magnetron#Health_hazards to decide for yourself.
Jan 2, 2011. 4:07 PMdog digger says:
You could just look at the wiring in the microwave before you start clipping wires.
I highly recommended not to power the magnetron up!
Sep 20, 2009. 9:17 PMmuttyfutty says:
Chill!!!! Firstly why the hell do you want to power up the magnitron? these things are WACKO dangerous! can cause cancer, etc... Maby its best ytou leave that component alone... unless you are firing it up in a propaly shielded and controlled inviroment
Apr 21, 2010. 9:12 PMne171pro says:
 Did you know cellphones are microwaves?
Did you know with phased array antenna, Tesla coil, microwave, oscilloscope and RF generator you can power all your house's with limitless wireless free energy, an so much more?  Even cure aids and cancer.
Apr 22, 2010. 1:04 AMmuttyfutty says:
Totaly Correct,
But there is a huge difference between hand/cell/mobile phones and magnetron (lol)
But, I'm not too certain on all the cure for AIDS thing...
Feb 23, 2010. 5:34 AMmaster key says:
You know I don't think a magnetron can cause cancer.
Apr 13, 2010. 6:27 PMtristantech says:
Actually, exposure to high-power electromagnetic radiation can disrupt cell processes and DNA which may lead to cancer.
Feb 24, 2010. 4:48 AMmuttyfutty says:
Well, According to wikipedia: "Some but not all studies suggest that long-term exposure may have a carcinogenic effect"
As well as produce cataracts.
eek...
not very nice at all!
(do you know how I remove those hyperlinks?)
Aug 13, 2011. 8:45 PMstatic says:
Jul 24, 2011. 2:05 PMtinstructable says:
In the magnetron side view, you have it down as "Neodymium magnets", not ceramic like it says below it.
Jul 10, 2011. 6:19 PMbajablue says:
I have a question... and you obviously KNOW what you're talking about, so here goes...
My microwave recently died. The turntable, inside light, timer bell and digital clock all work... EXCEPT nothing gets heated. I ran it with a ball of foil inside and nothing sparked.
I've already bought a new microwave and want to turn this one into something Instructably "special". It will be something that utilizes the turntable and the inside light when it's running. (lol... my ideas are keeping me awake at night!)
Is it safe to convert this microwave or should I remove some dohickey part to make sure?
Your advice would be much appreciated!!!
Jul 19, 2011. 7:39 AMHarlzter says:
Ours had a similar problem, even though on the back it states no user servicable parts there is a fuse inside which had blown, a really simple fix search ebay for miocrowave fuse they are dirt cheap (about £1.50). Sadly it was just the start of problems and its just gone again altogether so I cam on here to see what I could salvage from it.
Jun 16, 2009. 5:07 PMxBrainstormerx says:
What is a relay and how do you hook it up? Is it like a switch?
Jun 30, 2011. 8:23 PMmengstrom says:
most relays you can find for cheap are usually in tv's because of the high voltages. you can here the turn on when you hit the "on" button ( you would here a click noise). the actual connetion can handle a lot more than an actual switch of the same or smaller size.
Jun 29, 2010. 8:23 AMWarren.Sensei says:
The longer wire (ie the center of the sparkler) creates a larger electric field, thus allowing for arcs to be sustained within a larger volume around it.
Jun 30, 2011. 8:13 PMmengstrom says:
the smoke acts as a way for the arc to fly further, maybe thats why it long enough.
i actually use transformers only for amusement mini potato launchers, which i am thinking i should make instructions for it.
Nov 25, 2010. 2:45 PMflavors23 says:
the heaters are to heat the magnetron. not sure why but i know that it needs to be warmed up. the thermal fuses could be to shut them off when it gets warm
Apr 16, 2011. 1:36 AMdog digger says:
no they're not :)
Apr 16, 2011. 1:35 AMdog digger says:
I connected this up to a drill and it produced cool sparks
Mar 30, 2011. 6:29 PMTommy W says:
Can I use the fan pic for another instructable?
Mar 18, 2011. 8:51 PMJimmy Proton says:
Those arcs don't seem very powerful, I can stretch a 10cm spark with a single transformer.
1-40 of 228next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
767
Author:Plasmana
 "Energy cannot be created nor destroyed!"
more »
