3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Take Apart A Microwave
Step 13Power relay and light bulb
You can use the relay for heavy load switching and if the light bulb still works, you can save it as an replacement bulb for other microwaves.
5 comments
Jun 16, 2009. 5:07 PMxBrainstormerx says:
What is a relay and how do you hook it up? Is it like a switch?
Jun 30, 2011. 8:23 PMmengstrom says:
most relays you can find for cheap are usually in tv's because of the high voltages. you can here the turn on when you hit the "on" button ( you would here a click noise). the actual connetion can handle a lot more than an actual switch of the same or smaller size.
Sep 21, 2009. 2:42 PMgeekdude says:
ive seen videos of a lightbulb in a microwave and they glow verry brightly and then explode. what do they do to make sure the light that comes with the microwave does not explode?
Aug 6, 2010. 1:08 PMixonstater says:
The whole microwave is shielded against radiation, the magnetron feeds directly into the chamber. The light bulb is never exposed to radiation.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
778
Author:Plasmana
 "Energy cannot be created nor destroyed!"
more »
