Step 4Discharge the capacitor
You may get an loud "SNAP" (which is unlikely) and that indicate the capacitor is discharged, do this a few more time to really make sure the capacitor is discharged..
And you're done! The microwave is safe to gut out!
also, using two, if you are startled and drop them, they will always fall OFF of the cap. using a single screwdriver, you will occasionally weld the screwdriver to the cap you are discharging.
just some thoughts.
"you will need the following: a screwdriver, a wire-wound resistor with a 2 watt-20,000ohm rating, and a pair of jumper wires with alligator clips on the ends. Clip a wire to each end of the resistor. Clip one wire to the metal shaft of the screwdriver. Clip the other wire to one of the capacitor's terminals. Now, touch the other terminal with the tip of the screwdriver. There may be a small spark. If the capacitor has three terminals, do the same process with the middle terminal and each outside terminal."
I've also read that you should do the same from each terminal to the chassis.
Hey folks, here' s link to a guy who understands microwave repair really well:
http://www.repairfaq.org/sam/micfaq.htm. Has better details on doing this discharge thing.
For some reason, the link I originally posted is now bad. here is a better one:
http://repairfaq.ece.drexel.edu/sam/micfaq.htm#micsafdc
This guy is obviously experienced at this stuff and all I am doing repeating his good advice that I heard from several sources.
Frankly, I don't think Instructables should even allow these how-to's when there is a potential for DEATH due to the person giving the WRONG instructions. Even if the instructions are correct, someone can misunderstand, die, and then sue over that anyway.
PS: one cannot sue if they are no longer alive...
PSS: good job with doing your research, is is always a good idea to consult an expierenced person before attempting this type of project. but remember, there is always more than one right way to do things. you can discharge a cap in many ways, all leading to shorting the two terminals, whether it is direct or through grounding them both simultaneously. btw join ninja inc... my group.
