3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Take Time Lapse Photo's (CHDK)
video How To Take Time Lapse Photo's (CHDK)
In this video I'll show you how to take time lapse photo's, with a Canon Power Shot camera using an intervalometer script. It is only possible to do this after installing the CHDK hack on your camera. You will learn how to download the "counter.bas" script file, how to load it on your camera and how to run it. If you need to learn more about installing CHDK a link is provided in the video.
You Will Need...
Canon Power Shot Camera
CHDK Installed
SD Memroy Card
Mac or PC
SD Memory Card Reader
Step 1: Download The Intervalometer Script Zip File
A. Go to thsi web site http://chdk.wikia.com/wiki/Countdown_Intervalometer
B. Scroll down until you see the zip file "CHDK_Countdown_Intervalometer.zip"
Step 2: Un-Zip The Folder
A. Un-zip the folder on Mac using Stuffit Expander or on a PC using the default extraction tool
B. Notice the helpful text file that offers further explination on using the script
Step 3: Drag & Drop The Script File Onto Your Memory Card
A. The name of the actual scirpt file is "counter.bas"
B. Place the counter.bas file in the "Scripts" folder which is located in the "CHDK" folder
Step 4: Safely Eject The Memory Card
A. Place the memory card in the camera
Step 5: Turn On The Camera & CHDK
A. Use the "card lock boot" method or the "firmware update" method
Step 6: Press The Shortcut/Alt Button
A. This will toggle to CHDK mode
Step7: Press The Function Set Button
A. This will pull up the script loading menu
Step 8: Select Load Script From File
A. Select "counter.bas"
Step 9: Choose Your Parameters
A. Set the interval between shots which is measured in seconds
B. Set the total number of pictures to be taken in this time lapse sequence
Step 10: Exit The CHDK Menu By Pressing The Menu Button
A. Notice the text "coundown intervalometer" blining in the bottom left corner of the display
B. Mount the camera on a tripod
C. Dial in your desired settings
D. Press the shutter button
The script will run until the total number of shots has been taken, or until the battery dies, or until the memory card runs out of memory, which ever comes first.
You can save 10 parameter presets. This will save you time if you plan on using the same script parameters repeatedly.
BigNate84 How To Videos
9 comments
May 11, 2012. 11:35 AMsstanfill1 says:
hey can u help me with something btw very helpful video here
May 11, 2012. 7:44 PMsstanfill1 says:
is there a way i can continuosly power my canon sx230hs while taking a time lapse? need to know soon
May 11, 2012. 5:10 PMsstanfill1 says:
and can i plug my sx230hs into my iphone charger with the usb provided
May 11, 2012. 3:01 PMsstanfill1 says:
Mar 13, 2012. 11:30 PMward_0140 says:
Thanks for the instructions. I am thinking of using this method for aerial photography so my question is... Will this intervalometer focus each time it takes a photo or is the focussing done during the very first depression of the shutter button?
Mar 18, 2012. 6:29 AMward_0140 says:
Thanks, I have installed CHDK with the help of your instructable and it works perfectly with autofocus. Cheers.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:BigNate84(YouTube Channel)
I'm a Certified Technology Specialist and CAD Engineer for a video conferencing company. I keep up with technology and produce How-To videos. Life Skills, Hacks, Photography, Reviews, Automotive, Aud...
more »
