3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Turn Your LG EnV 2 Cell Phone into a portable Dial Up Modem for your Laptop (or desktop)
We've all at somepoint had that need to use the Internet where it just hasn't been possible, such as in the car, or on vacation, where they charge a costly amount of money per hour to use their wifi. finally, I have come up with a simple way to get online no matter where you are.
There are two options to connect to the internet.
you can use your phones data service line by calling #777. please note that this will require a costly plan (for verizon an additional 60$ to your existing bill), but is the fastest plan available, giving near high speed internet
if you pay a monthly subscription for AOL, you can use their access numbers to connect to the internet. this is the cheaper and better value if you already pay the $30 a month for AOL or whatever it is. This option is miserably slow, with speeds around what i believe is 14 kbits, a slow dial up connection. with this connection, you will be able to use things like AIM and Email, but websites like facebook and youtube can take up to 5 minutes to fully load if you are lucky, and most of the time just time out (other words it gives up).
So with this being said, i will explain how to connect to verizon's service first, followed by connecting with AOL dialer, a program that comes with AOL 9.1.
Step 1Some Things You'll Need
Some Things You\
you will need
An LG En V 2 (I'm sure you can replace this with any other phone as long as it can be used as a modem, check with your provider to see if your phone can be used as a modem)
A Compatible USB Data Cable (LG EnV 2 uses a USB to Micro USB cable, which is availible online at websites like Newegg. This cable interface is newer, so it may be hard to find in stores.
A Laptop, Preferably with vista, or you will have to hunt the drivers down on the Internet. i believe Verizon has a driver and USB cable combo for a reasonable price
The driver (as mentioned above) vista will find it for you automatically
23 comments
Aug 22, 2008. 1:31 PMthejrb says:
Yeah the usb cable and the internet service. Your basically using your phones internet and displaying it on a laptop screen. I also know how to get free internet on the env2 guess I'll do an instructable on it.
Aug 29, 2010. 12:44 PMboiddude says:
How do I go about using it to get the free internet. I had a palm treo and had to use an application on it for it to work. I would greatly be appreciative if you can help.
Aug 23, 2008. 7:21 AMthejrb says:
My phone shows up just fine on my computer with nothing but the phones drivers.
Aug 22, 2008. 7:04 AMj626no says:
does this cost anything? sorry, i didnt have the time to read the entire 'ible...well put together from what i have read though.
Mar 16, 2010. 11:18 AMcyrozap says:
 myfreewirelessisp.com is what I use. It works fine. It's slow, but it's better than nothing.
Dec 8, 2008. 2:13 PMcyrozap says:
Bluetooth modem on VZW LG ENV2 does not work, I will try to find a solution.
Mar 16, 2010. 10:00 AMcyrozap says:
 Bluetooth modem actually works, my mistake.
Dec 11, 2009. 12:38 PMFoaly7 says:
Does it have to be an EnV 2?
Dec 7, 2008. 1:35 PMcyrozap says:
I bet you can do this using an ENV2 (I have one) as a bluetooth modem. It would probably work the same way.
Apr 24, 2009. 5:57 AMRimwulf says:
try this:
http://www.myfreewirelessisp.com/ provided by SoCal.net both free NetZero provides 10 hrs free a month or unlimited with accelerator for about $5. try going here and look up others:
http://www.free-internet.name
it has lists from all over the world.
Dec 8, 2008. 2:06 PMcyrozap says:
I've also tried sending AT commands over bluetooth to the cell phone modem using hyperterminal. It didn't work. I did get a response when i tried to dial using the computer, though.
Dec 8, 2008. 2:08 PMcyrozap says:
According to the text that appears on my phone, "Dial-up networking service is not supported." Stupid Verizon and their locking out of phones.
Mar 16, 2010. 7:52 AMcyrozap says:
 Hey, cool! I found the option on the phone to enable the data modem! Just Google it.
Oct 22, 2008. 9:59 AMjmsmny says:
I have two needs: First I need to use my phone to connect directly from my laptop to another modem. Just like my modem does with a land line. Second I have earthlink as a dial-up Internet provider, can I use my phone to connect to the Internet through earthlink?
Oct 27, 2008. 1:06 PMjmsmny says:
If I can dial into the earthlink modem, I should be able to dial into any modem correct? I currently dial directly into a bank of modems from my laptop using my land line. Once logged on to the network I have access to the computer and software that I support. There is no internet access available yet.
Oct 21, 2008. 5:25 AMtfaulk26 says:
On step 2, I was prompted for a driver. Unfortunately, I have misplaced the CD that came in the package from my provider, Verizon (I presume, CD had the driver). I could not find a driver on the internet. If someone knows - please point it out to me.
Sep 13, 2008. 7:15 AMGlitch007 says:
You can also "share" the connection through bluetooth, if your laptop is compatible. All Mac's have built in bluetooth, from my knowledge.
Aug 27, 2008. 8:24 AMheyzuphowsitgoin says:
theres a free dial up service... i forget the number... but it works just as well, you just have to use the built in dial up thing in windows... here... it might only work in nh, or new england (602)3715050
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:NT86
