Introduction: How to Use a Slide Rule!
Picture of How to Use a Slide Rule!
Hate when your stupid calculator runs out of batteries?!
well go oldschool with the classic slide rule.
Do complex calculations in a flash! go slide rules!
This instructable will only teach you how to multiply, and do functions with pi.
The rest you will have to figure out on your own!
Step 1: Get a Slide Rule.
Picture of Get a Slide Rule.
Get one from ebay here
Amazon does not carry them
David Crate's rules here
Slide rule guy here
And for you canadians eh.
This instructable is based on stick slide rules, and not circular ones. However, the concept is the same.
Step 2: What to Do!
Picture of What to Do!
1. slide the middle part of the slide until the first number you want to multiply by is on the "c" scale, and is lined up with the second number on the "d" scale  (bottom slide).
2. slide the clear part with the line on it until it reaches your second number ON THE "c" SCALE!
3. The number that the line lines up with on the "d" scale is your final result.
Step 3: Example.
Picture of Example.
For this example I will multiply 2 by 4
See pictures!
Step 4: Pi!
Picture of Pi!
For this example I will multiply pi by 7, as a simple indication of what you can do.
Step 5: Trouble Shooting
Picture of Trouble Shooting
If the slide doesn't compute correctly by sliding it to the right, slide it to the left.
More complex options probably have more trouble.
Step 6: More Complex Things.
Picture of More Complex Things.
"Phil B says:
There are a lot of links to other resources at this Wikipedia article , including some you gave in your Instructable.  A couple provide templates to download for making your own slide rules.
Here is how slide rules work for multiplying and dividing.  Each number has a logarithm.  To multiply two numbers, add their logarithms and find the anti-logarithm of the sum.  Division involves subtraction of one logarithm from the other.  A slide rule represents logarithms as a distances along a linear scale.  Add the distances to multiply.  Subtract the distances to divide.  The numbers on the scale are the anti-logarithms of the logarithms represented by distances on the scale, so there is no need to consult a table of anti-logarithms.
All of the great engineering marvels until the 1970s were done on slide rules.  Because a slide rule is accurate to only a couple of decimal places, those marvels are all a little over-built.
Here are some links if you want to know more:
Bing
Google
YouTube
Other 'Ibles
chrissysno (author)2012-01-29
It's an OK instructable, but most would find it pretty boring.
ckoehler1904 (author)2010-04-28
I always think of the NASA engineers using their slide rules at a critical juncture in the movie "Apolo 13".  Hard to believe that they didn't even have pocket calculators back then.....
Phil B (author)2010-04-26
There are a lot of links to other resources at this Wikipedia article, including some you gave in your Instructable.  A couple provide templates to download for making your own slide rules.
bertus52x11 (author)2010-04-26
I have one here at home and always wondered how they work. Thanks.
implaxis (author)2010-04-25
Spock even uses a slide rule in an early episode of Star Trek!
About This Instructable
4,591views
18favorites
License:
More by Buzzsushi:How To Use A Slide Rule!Making great looking images with powerpoint 07Make A Coffee Cup Tissue Dispenser
Add instructable to:
