Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
http://www.instructables.com/id/Get-Perfect-Tie-Length-Every-Time/
You should mention that this is a 'half windsor' knot. For those without the same neckline, the reference point when aligning the tie at the start is from where the wrap-around meets the portion that has an obvious stitching.
Also, (though I prefer my ties a little shorter) it's generally observed that the proper length for a tie is for the tip of the wide end to touch the top of your belt.
