I've been noticing that a lot of people (not people on instructables, but people interested in electronics in general) don't really know about LED's. No one in my science class at school had ever even heard of them. This is an easy introduction to LED's that should teach you the basics. It's good if you're interested but have no idea where to start. I also thought this would help out anyone wanting to enter the contest, but it took me a while to finish.
Remember, (As always) feedback and ratings (positive or negative) are always appreciated!
FOR MORE INFORMATION SPECIFIC TO WIRING, YOU CAN SEE NOAHW'S INSTRUCTABLE "LEDs FOR BEGINNERS"
Remove these ads by
Signing UpStep 1Name/Background Info
LED is an acronym for Light Emitting Diode. Well, you ask, what on earth is a diode.
A diode is a device that, in simplest terms, allows electricity to flow through one way but not the other. Those of you who are knowledgeable about mechanical things could think of it as sort of a check valve. If you have no mechanical knowledge, disregard that last sentence.
Now that you know what a diode is, an LED is just one that emitts light (But you could probably figure that out just from reading the name).
Often LED's have equal length 'legs', so to work out which one is which, look closely inside the plastic with a mag glass, the negative is the side with the bigger surface area, or looks like an upside-down 'L'.
The power supply is often 12 volts DC (a battery, or transformer). But can be 3 volts to about 30 volts DC, (Normally.)
The current limiting resistor is very necessary, if you want the LED to last any time, and a proven value to use with 12 volts, is 470 ohms. This will limit the current to 0.025 Amps, i.e. 25mA. This is using the common formula from 'Ohm's law', V/A=R, so in this case, 12/0.025=480 ohms.
It is best practice to fit it between the Positive of the LED and the power supply's positive terminal.
LED's can be bought in various shapes, round, square, rectangle, and in various colours, red, green, yellow, orange and blue. Hope the photo helps.
has very low prices on l.e.d.s compared to other stores.
Buying parts online from wholesalers and surplus outfits is usually the cheapest way to go. Standard LEDs can be had for around 5 to 10 cents each, while high brightness ones will usually be a little more. Blue/violet, white, and UV LEDs are the most expensive, but can often be found for $0.75 or less each. Some places to look include:
http://www.allelectronics.com/
http://www.mpja.com/
http://www.mouser.com/
http://www.digi-key.com/
Then theres eBay. Search and you shall find. There are a lot of good deals and hard to find items around on eBay that most people never think to look for.
blue and green use 3.4 volts. IR are by themselves and about 1.2 vdc. as an example 3 white leds in series are 10.2vdc. if a 12vdc supply is used 1.8 vdc, left to be dissapated, /.02 =90 ohms. 100 works great. for 13.8 vdc use 180 ohms. for a brighter light parallel up several strings. best of luck to all. Uncle Cy
thanks for your questions. first watts is power not resistance. a 3vdc led that draws .7 amps is indeed a 2.1 watt burner.
my intent was to determine the value of the current limiter. you only use the difference between supply and forward voltage for the LEDs. if you have 3 white LEDs in series that's a forward voltage of 10.2 vdc. if the supply is 12vdc then 12 -10.2=1.8volts. 1.8 vdc / .02=90 ohms. 100 ohms would work perfectly. if the supply is 13.8 then 180 ohms is needed.
think of the string of LEDs as one entity. it is limited to .02 amps (20 ma). we only need the difference between the supply and how many volts the string of LEDs "eats". we are not figuring the resistance of the whole string, only the missing part.
P=E X I. no resistance in the formula for power. you seem to have ohms law down.
you are trying to figure the resistance of the entire string which is not what we were intending to do. you only need to figure the missing part which is easy to calculate. we know the current (.02 - limited by properly biased diodes) and the supply minus the total voltage of the Diode string. this gives us the voltage of the unknown value we seek. then basic ohms law and we have the needed resistance of the current limiter.
if you are still confused please let me know and i'll try again. thank you
