3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Use LED's
Step 7Now You're Ready!
Now You\
With these "Tool Tips" (sorta) and a completed LEDucation (sorry, couldn't resist) I hope you can get out and build some cool LED projects. Remember, I really do appreciate any type of feedback or ratings.
13 comments
Sep 15, 2011. 4:32 AMMike_MK says:
A few tips;
Often LED's have equal length 'legs', so to work out which one is which, look closely inside the plastic with a mag glass, the negative is the side with the bigger surface area, or looks like an upside-down 'L'.
The power supply is often 12 volts DC (a battery, or transformer). But can be 3 volts to about 30 volts DC, (Normally.)
The current limiting resistor is very necessary, if you want the LED to last any time, and a proven value to use with 12 volts, is 470 ohms. This will limit the current to 0.025 Amps, i.e. 25mA. This is using the common formula from 'Ohm's law', V/A=R, so in this case, 12/0.025=480 ohms.
It is best practice to fit it between the Positive of the LED and the power supply's positive terminal.
LED's can be bought in various shapes, round, square, rectangle, and in various colours, red, green, yellow, orange and blue. Hope the photo helps.
Mar 25, 2009. 12:33 PMElephants Are Fat says:
do you where you can get a large amount of LED's?
Jan 29, 2011. 11:25 PMikoneckox3 says:
i bought 100 with 100 resistors on ebay for about $2.00, and after shipping (hawaii) it was $7.00 they seem to work fine too- and if you dont want to buy online, you might be able to try LED christmas lights :]
Jan 2, 2011. 4:51 AMasdftzui says:
go to the store dude.. u will find large amount of LED's..ok..
Apr 23, 2009. 4:55 PMtanmanknex says:
http://www.moddersmart.com/en/loose-5mm-led-blue.html
has very low prices on l.e.d.s compared to other stores.
Aug 6, 2010. 3:13 PMJ3PPiSH says:
Thanks I really learned from this!
Feb 4, 2008. 9:40 PMDerelicte says:
How much are LEDs from Radioshack? Is there any better place to get them?
Sep 30, 2009. 8:32 AMkadris3 says:
send me an s.a.s.e. and I'll send you some. see below. Uncle Cy
Jun 1, 2009. 10:40 AMSwishercutter says:
Ebay...I use Digikey for new specific parts but for the price you can't beat ebay. In my case the person sent the resistors (5 band precision ones) for free when I bought the LED's. Not that resistors are expensive but it's still nice to not have to buy some.
Feb 5, 2008. 1:07 AMburzvingion says:
It's usually only prudent to buy anything from radioshack if you absolutely need it immediately and there are no other brick-and-mortar stores in your area that will sell said item. Almost anything you buy there, from LEDs to batteries to plastic project enclosures, will be marked up around 500%. It's a little bit like buying groceries at a gas station, except worse, because it happens to be the only gas station in town.
Buying parts online from wholesalers and surplus outfits is usually the cheapest way to go. Standard LEDs can be had for around 5 to 10 cents each, while high brightness ones will usually be a little more. Blue/violet, white, and UV LEDs are the most expensive, but can often be found for $0.75 or less each. Some places to look include:
http://www.allelectronics.com/
http://www.mpja.com/
http://www.mouser.com/
http://www.digi-key.com/
Then theres eBay. Search and you shall find. There are a lot of good deals and hard to find items around on eBay that most people never think to look for.
Apr 5, 2008. 11:09 AMkadris3 says:
if any student is broke, but wants a few leds to play with, i would be happy to send them to him. send me a stamp and some of my slow movers, pulls, or drops will be sent for your playing pleasure. they will all light when they leave here. when an led hits the floor, i cannot tell which bag it came from. i know the color, but not the intensity. please tell me your grade or yr in school. i'm happy to help but don't appreciate getting lied to or ripped off. also on the website is ohms law instruction fr figuring resistance. questions are a click away under "ask uncle cy". u don't need a bundle of money if u know an old fart like me! unclecytheledguy.com
May 28, 2008. 9:20 AMxCeasarx says:
soooo...can u like take a LED from anything like a ps2 controller or cable box annnndddd...can u connect it to anything with power or energy that it can handle
Jun 1, 2009. 9:14 PMvpbotbuilder says:
Yeah, you can also use a resistor which resists the amount of current that fllows through the LED so that it can last longer
Feb 14, 2009. 5:37 AMstepe says:
Hi! Thanks for all the great info no LED!! Unfortunately, I am new to both Instructables and crafting in general, so I have one question..I know it is silly, but..well, I would like to know where you connect LED lights to, I mean what would be the power source.. Thanks in advance!
Jun 1, 2009. 9:11 PMvpbotbuilder says:
its not silly, when i first started using LED's, i didnt know either. You would simply connect the LED to a battery.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
75
Author:Gjdj3
Music, chemistry, electronics, etc.
