Introduction: How to Use Your Android Tabletas a Secondary Monitor With IDisplay App
This is My First Post on Instuctables so i am just sharing My own post From my Website
Andro Root:How To Use Android Tablet as a Secondry Monitor
Today i am going to explain the way to convert Android tablet as Secondary Display.Yes this is true If you own an Android tablet then you can use it as as Secondary Display. Android tablet is a perfect substitute for a second display due to its larger and smooth screens.but its not mean that your Android SmartPhone Will Not work.
Follow this handy guide and use your Android tablet as Second Display easily.
Step 1: Requirements
1.Android Tablet (Android 3.01 or newer)
2.iDisplay download it from Google Play Store:-
idisplay app
Rating: 3,votes-‎2,427,Price- ‎US$ 4.76
or iDisplay v3.0.1 APK full free mod version
idisplay app mod apk
3.Desktop or laptop (Windows XP, Vista or 7. or Mac, OS X Leopard or newer)
4.Wireless network :-if you want to use as wireless Secondary Monitor.or connecting Data cable.
5.Companion client :- can be downloaded from the vendor's website
Here
Step 2: IDisplay by Shapeand
I choose iDisplay because It supports Android, Windows, iOS and Mac. You need a compatible tablet running Android 3.01 or newer and your computer .Installing the app is as easy process you just have to open the Google Play Store>Search iDisplay>and tap on Download (Link is also given Above in Requirement). The app isn't free,(But there is many mod apk are available on the net sorry for sharing a mod apk but this is necessary ) and will require you to set up a Google Play account. This will be linked to your Google account so you only need to enter your credit card details once.When this is done, the next thing to do is download the app and open it. You will be presented with one option -- connect via USB. If you want to connect over Wi-Fi, you have to download a client for your windows PC or Mac.(If connecting via Wi-Fi, you have to make sure both tablet and PC are connected to the same network) .Once setup is complete, you'll have a new, touch screen display that will help you to complete any project in a shorter amount of time with better space to work.
Step 3: Method 1:- Connect Via WiFi Network
To use Tablet as Wireless Secondary Monitor,
Follow This Guide:-
1.Download and Install iDisplay app to your Android tablet.
2.Download and install desktop client to your computer and run it:-While installing, it warns you that it will also install a video driver and asks you to click OK to install this driver. The installation also requires you to reboot the machine & again Makesure your computer and tablet are both connected to the same Wi-Fi network..
3.Set up permissions/allow firewall exceptions:-A Windows Firewall exception request appears, and after allowing the exception and joining both devices to the same wireless network, we can make a connection between the tablet and the desktop.A dialogue box pops up and here you can either allow iDisplay to connect to the tablet once only, always allow or deny. I chose always allow.(as Picture Above)
4.Open the app on your Android Tablet and select your computer's name.
5.The screen should flash, and your tablet should be connected.
6.You may need to pinch-and-zoom to correct it, or you may need to disconnect and reconnect,If the size of screen on your tablet seems small. After everything done You can see the Success message as below click on OK and Enjoy.
Step 4: Method 2:- Connect Via USB Data Cable.
To use Tablet as Monitor via Data Cable,
then Follow This Guide:-
2.Download and install desktop clientto your computer and run it:-While installing, it warns you that it will also install a video driver and asks you to click OK to install this driver. The installation also requires you to reboot the machine.
3.Set up permissions and allow firewall exceptions:-A Windows Firewall exception request appears,and after allowing the exception and joining both devices with the connecting data cable, we can make a connection between the tablet and the desktop.A dialogue box pops up and here you can either allow iDisplay to connect to the tablet.(as Picture Above)
4.Open the app on your Android Tablet and tap on connect via USB and then select your computer's name.
6.You may need to pinch-and-zoom to correct it, or you may need to disconnect and reconnect,If the size of screen on your tablet seemssmall.After everything done You can see the Success message as above click on OK and Enjoy.
Just open any task like My Computer > Drag it with your mouse pointer and swipe to the Right side of the screen.
So now you have successfully connected Your Android SmartPhone to Your Computer As Secondary Monitor and you can also do web browsing, Read Document or mail and you can also watch any movie on your android SmartPhone.You can Adjust the settings from your Computer's tray icon.
For more Guides and tutorials Please visit my website
Andro Root
About This Instructable
3,447views
30favorites
License:
Bio: My work is my Introduction.My website:- http://www.androroot.com
More by SKYuvraj:AndroBotHaptic Proximity Module - Cheap and EasyTraffic Light System with Pedestrian Crossing lights
Add instructable to:
