How to WABBAJACK TOP PROP!
Published
Introduction: How to WABBAJACK TOP PROP!
We're going to make a project so cool even the Daedric Prince of Insanity would appreciate it!
Just so everybody knows this has my own personal flare to it, so don't compare too harshly. Also the rule of "there are no mistakes, just unexpected changes in design" applies here.Also this is the 2nd 'in the round' carving I've ever done!
Step 1: Tools
The tools needed for this project are:
Hand saw
Drimel
Chisel
Hammer
Rasp
Rag (for staining)
Also wood stain and black enamel
Step 2: Basic Shaping
Originally this was a square bed post leg, but we sawed it down to an octagon, then. Used a rasp to round it out
After that we used a portable drill and a hole saw to make 3 holes. The holes would've been alot more even, but I neglected to measure.
However I still like the way it came out
Step 3: Inside
This is what it looks like ion the inside.
See how rough it is on the inside at the moment?
Step 4: Making the Outline
Make an outline of the face you want to carve
Step 5: Carving and Smoothing Out
Carve the face into the wood, then use the dremel to make it more round and smooth
Step 6: ==>
Rasp and make the tops of the heads round
Step 7: Round Off the Tops Even More
Step 8: Clean Out Inside the Mouths
I used a small circular file to round out the inside and make it less rough.
I also rounded the edges of the mouths
Step 9:
I chiseled one half of under the mouth down towards the mouth, and the other down to the end part. Then I chiseled the sides until it was round.
I used the Dremel to fully round the beard, and detail it
Step 10: Lowering
Lower everything except the faces, so that the faces are out
Step 11: Sizing
I had sized it to this staff I was going to use.the staff itself proved to be too difficult to get how I wanted. So I just decided to make it a statue type thing
Step 12: Staining
I used a couple coats of Ebony stain to get that black color.
It settled into that more dark color
Step 13: Painting
I detailed the low lights (where the darkest parts should be/ the shading) by painting it with black Enamel.
I decided to make the inner mouth area, to try to copy the actual Wabbajack, but it would also look awesome with that warm brown color it had before.
Step 14: Thank You
Thank you for reading!
This took me about 3 days to make (3 day weekend).
Again there are a few mistakes, and quirks. But I'm only human, and this is only my second 'in the round carving', so for that standard it's amazing!
All in all I had a blast! And it's kinda cool making something with just tools I can hold in my hands!
Don't forget to vote for this if u enjoyed it :D!
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    4 Comments
    a very cool idea. I think if I give it a go I will do the staff and head from one piece of stock as I can see attaching it to the staff and making the transition to the staff look smooth being quite difficult to do. thanks for sharing :).
    Thank you both!
    I will definitely use that if ice in the future
    I think it looks good. However you should take a couple of natural light photos of it to really show off the color at the end. The color looks a little washed out in those other pictures. Because of the light used in the last photos.
