Introduction: How to Install a Pc Fan
this is my first instructable on how to cool your gaming pc with a fan
Step 1: Materials Needed
materials needed
120mm PC fan (doesn't have to be Corsair, it could be any 120mm-sized fan.)
screws
zip ties (optional)
Step 2: Remove Your Side Panel
remove the screws holding the panel to the case. (there may be more than two screws depending on your case.)
Step 3: Find Your Spot
find a 120mm fan slot. locate your point where you connect the fan. Your point will have 3 pins on it and may have a plastic groove to help line up the pins.
Step 4: Screw Your Fan Into Place
make sure your screws go in straight. you should have at least two screws holding the fan on. Four screws would be optimal.
Step 5: Replace Your Side Panel
There may be two or more screws keeping the panel on. make sure to put all of them back in.
optional: secure your wire into place with zip ties to keep it out of the way.
Step 6: Admire Your Work
look at your newly installed fan
