How a USB Works: The inside of the cable
Hi all, My name is Dexter, I am 15 years of age and this is my first instructable. It will show you the inside of the USB cable. And will show you how to connect a light to it. NOTE: Do not directly connect an LED to a USB cable, use a resistor. I appologise for the poor quality of the photos.
Step 1Strip one end of the USB cable
Strip an end of the USB cable, remember to leave a USB port on one end, show the wires inside (with their coloured covers). The wires should be the same as in the photo below, the red wire = 5 Volts (+) and the black wire is the ground (-), for now ignore the other two wires I will hopefully make an instructable about them at a later stage. We will only use the black and red wires for now.
22 comments
Feb 24, 2011. 6:25 PMFlying_MashedPotatoes says:
yet you dont tell us what resistor to use... not even a link to where they say what rated resistor for what voltage of LED.
Mar 30, 2011. 2:25 AMVoid Schism says:
Just use Ohm's Law V = IR
or R = V/I = 5/20e-3 (for 20mA diode)
so 250 Ohms
Seeing as electronics isn't an exact science use a 220 Ohm resistor or try using combinations of resistors. Don't be afraid of a little trial and error :)
May 14, 2010. 7:09 AMllamma1010 says:
 My cable is slightly different i have a lot of thin exposed metal wire along with ones you have the red is + the black is - and the exposed wires are ground
Jun 5, 2010. 7:42 AMgodofal says:
thats just another ground
Jul 1, 2010. 5:58 PMiabler124 says:
Actually those wires are there to protect the Black, Red, White, and Green wires.
Jul 4, 2010. 2:32 AMgodofal says:
i thought it was connected to the metal casing of the USB connector?
Feb 9, 2011. 12:57 AMDream Dragon says:
A late addition to the conversation and hopefully you have already found the answer to your question, but for people finding this thread from a search, the exposed metal wire sounds like "Shielding". It is intended to reduce interference from other signals close by and should not normally be used as a "ground", or "return", though in some cases it may go to "Earth" which is NOT the same.
Feb 10, 2011. 7:51 PMgodofal says:
late, but not unread ;)
nice info, ty
Oct 17, 2010. 7:19 AMHanashimaru says:
Thanks! This instructable actually cleared things up for me =D
Jun 3, 2009. 6:49 PM324506allas says:
thank you I am only 12 and this me a lot
Jun 7, 2010. 6:28 PMManyuX95 says:
I don't know why people post their age, and I didn't understood what you said :)
Jun 17, 2010. 11:43 AMneil maclennan says:
why so much negativity?
Jun 28, 2010. 3:56 PMManyuX95 says:
It is not negativism, it is just that, it seems dumb to do it.
Jun 16, 2010. 12:50 PMdombeef says:
"and this me a lot" Huh? And i guess that they are saying that they are young and foolish?
Jun 14, 2010. 12:50 AMSterLuMan says:
i think thats just a simple christmas light or a little light from a toy... and a great tutorial...
Feb 19, 2009. 3:31 PMlittlegandhi1199 says:
Hi i'm 14 years old and.. I already knew that , also like a million other people have been doing that as in connecting lights but what i am looking for right now is how to use the other green and white wires for your use
Jun 6, 2010. 12:12 AMzack247 says:
too bad you need a microcontroller...
Jan 14, 2009. 2:19 AMHerminator says:
is your name really Dexter, lol i love that show :D
Aug 16, 2008. 3:30 PMJBizzle says:
thats pretty cool. I dont believe I've ever seen inside a USB cable. lol
thanx =]
Nov 26, 2008. 11:00 AMColonel88 says:
THE cable part was cool but the light not so much.
Oct 4, 2008. 7:27 AMrailpressureflip says:
Wow its pritty cool to see such a young boy with electronics knowledge. Good one =)
Aug 17, 2008. 10:51 AMgamer says:
Second sentence ("It will how you the inside of the USB cable. ") doesn't make any sense, but other than that, cool! After reading that sentence for the 10th time, I realized that you probably meant "It will show you the inside of the USB cable".
Thanks for posting
-gamer
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:luster123
