3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How boost your electrics tools.
video How boost your electrics tools.
With this tip you can increase electric motor speed by 200%.Make less friction on the shaft.
19 comments
Apr 1, 2008. 2:54 PMCameronSS says:
How are you measuring the speed? Given the vibrating, this is an unbalanced, cheaply made motor. At 175,000 RPM it would tear itself apart and probably fling shrapnel clear through the wall. A finely tuned jet turbine can spin at less than 150,000 RPM. A $5000 9" Advance DC motor will explode at 30,000 RPM. A cheap 3V motor will be quite a bit less.
Apr 5, 2011. 6:19 PMDumchicken says:
he ment 175 dude
Apr 5, 2011. 2:02 PMDumchicken says:
aka
http://kipkay.com/videos/just-for-fun/magnet-mania/
Mar 16, 2009. 1:32 PMGMer56 says:
I think that there is a higher risk of burning out the motor while doing this though, but good find!
Oct 13, 2008. 1:59 AMsypher says:
dude it is a turbo for electric motors, but there has got to be some kind of energy cost in doing this. i understand what is happening, but it also has to burn more juice to do it.
Jul 31, 2008. 7:16 PMBardouv says:
I remember doing something similar as a small child messing a round with small hobby motors.
Jun 9, 2008. 11:45 AMRasushi says:
where can I find those magnets? :D
Apr 28, 2008. 1:38 PMmoris_zen says:
Nice!
Apr 1, 2008. 4:14 PMhock3ydud3 says:
wow, that works great! i never even thought about adding some of my neodymium magnets to make my motors go faster, thanks for the tip!
Apr 1, 2008. 8:39 AMkillerjackalope says:
If this even works how on earth does it work?
Apr 1, 2008. 9:16 AMthearchitect says:
It works, I remember when I was a kid I had a high grade DC motor which had removable magnets on the sides. If I removed one, the speed would go down. But if I added the removed one on top of the other, the speed would go tremendously high (with less torque, though). Must be some electromagnetic phenomena... K.
Apr 1, 2008. 9:18 AMkillerjackalope says:
interesting and really quite odd...
Apr 1, 2008. 9:15 AMcode_e says:
It helps reduce loading across the variable flux capacitor. Tends to work best during April 1st for some reason..... ;)
Apr 1, 2008. 9:16 AMkillerjackalope says:
lol clever...
Apr 1, 2008. 9:17 AMkillerjackalope says:
I got that bit but why does it reduce the friction?
Apr 1, 2008. 11:15 AMw1n5t0n says:
I don't think that it reduces the friction. Here's a possible explanation: the electromagnets inside the motor generate their force by pulling and pushing against permanent magnets fixed around the axle. That's how the motor turns to begin with. By adding a stronger magnetic field around the motor, the pulling/pushing force is increased dramatically, and the speed of the motor increases. That's my guess, anyways...
Apr 1, 2008. 3:47 PMkillerjackalope says:
Now that sounds like a poroper explanation, which means loup226 is a very confusing person as he says about friction, granted I can think of a few ways magnets could reduce friction...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:loup226
