3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How not to block cameras
There has been an influx of projects on the internet claiming to protect an individual from surveillance cameras. Some use lasers. Others use balloons and static electricity. The ones that I found most intriguing used infrared (IR) LEDs.
I resolved to replicate the projects that used IR LEDs. Towards this end, I lined the hood of a hoodie with 10 high-intensity IR LEDs all the while documenting the project to share with others. In fact, I was super-excited to share this project with others when I was done with it. So, modeling my project after those that came before me, I inserted the LEDs, wired them up, plugged it in and took a picture of myself with a camera modified to view IR light. When I flipped the camera around to look at the picture, the first thing I noticed was that it hadn't worked. Instead of creating a halo of light in place of my head, I looked like I was wearing a sweatshirt lined with Christmas lights.
I was ready to write the whole thing off as a fake, but I figured that perhaps the project required some more thorough testing and that is precisely what I did.
Update: Please stop telling me I used the wrong kind of IR LEDs, I powered them incorrectly, I used the wrong kind of camera (I didn't), the LEDs are meant for pulsing or that you are simply smarter than me (I don't care).
Most of you are missing a key point. The simple fact of the matter is that the viewing angle (even a high viewing angle) will not protect you if you turn your head slightly away from the camera. Assuming that you will not always know where the camera is, the prior devices that my work is modeled after won't do much to help you.
In short, it is of my opinion, that we have all probably been misled.
Cryptography that only works maybe sometimes if the hardware is old enough and Jupiter is perfectly aligned with Saturn is ineffective cryptography. The same could be said for personal-protection camera blockers. If the device is incapable of hiding your face from every IR camera at every angle, at all times, then it doesn't work. Heck, I would settle for a device that can hide you from all IR-enabled security cameras at night, but I even doubt this is possible using current methods.
Like I said, if anyone can take my experiment and make it work without altering it too much... take 12 5mm IR LEDs with no more than 12v of power and make it work at all viewing angles (without the addition of optics), I would be actually very pleased to be proven wrong. However, I am suspicious as to whether anyone can do this given these parameters.
Step 1Establish a method
Establish a method
The first thing I wanted to do was to determine where my project had failed and how I could change my project so that it could work as intended. Next I wanted to analyze the design of those that had claimed to build working models. Finally, my goal was to analyze all of this information to
So, I thought of the reasons my project failed:
1) The LEDs were spaced too far apart
2) The viewing angles made some of the LEDs seem to be turned off
3) There was only 5v of power
4) My camera's resolution was too high
5) I took the picture from too close
And then I looked at some of the other projects that seemed to work. The first one I examined was by aKaMaKaVeLy. After my initial test, this one seemed highly suspect for a number of reasons. First off, it used a 9v battery and no resistor. That alone made it seem fishy. Next, the LEDs were spaced out around the hat at about the same distance mine were around the hood. Last, throughout the video, everything was done as video except for the two quick shots of it working that were still images. From this project I took away very little.
I next examined the project made by URA / FILOART. Their project seemed slightly more believable. They used 12 LEDs powered by 12v of electricity that were centered on a headband. I figured if any project was going to work, it would have to be theirs.
So, I resolved to buy a host of IR LEDs from the Electronic Goldmine and conduct tests with 8 LEDs (the minimum number aKaMaKaVeLy claimed were needed) and have them be centered on the forehead like URA / FILOART had done. I would power it at 12v and take a shot from the front and the side. A successful test would block the camera from all directions with 8 LEDs centered on the forehead powered using 12v (with a 220 ohm resistor).
113 comments
1-40 of 113next »
Jul 11, 2011. 4:26 PMbschran says:
Hate to say it but most security cameras like the one pictured are IR cameras... you would actually be helping the camera along by having that on you.
Nov 29, 2011. 8:22 PMilpug says:
True, but that isn't the premise of the idea. Normal cameras use visible light, and if you shine a really bright light at them , that part of the camera is blinded in the film/photo. The same is true with IR cameras. It seems like this would work, you would just need one super-powerful IR light to do it effectively.
Oct 26, 2010. 5:14 PMelectric_piano_5k says:
For further proof, see the cover photo for my "Infrared night vision digital camera/camcorder" instructable.  It is an IR photo of a second identical IR camera which is pointed ALMOST straight at the camera taking the photo. Even at this slight angle the IR LED's are dimmed enough that my face is clearly visible.
Jun 26, 2010. 11:36 PMnutsandbolts_64 says:
Have you tried diffused LED's?
May 9, 2010. 8:33 AMnoahh says:
 I'm not questioning your results, but how did KipKay do it?
Jun 12, 2010. 12:35 AMpolymeme says:
Right at the end of that video there are a few frames where he moves his head slightly and the brightness from one or both of the LED's drops substantially - to the point where you could see his face. That's the point he's trying to make here - that this only works if you point the LED straight at the camera at all times.
Jun 12, 2010. 12:09 PMnoahh says:
Oh, I see. Thanks.
Jan 11, 2010. 8:30 PMFashim says:
A Balaklava with lots IF LEDS attached would be quite the handy
Aug 26, 2008. 8:02 PMectorcab says:
Come on, i know its fun to play with electronics but just put a mask/hat/stockings over your face and go to work
Aug 29, 2008. 10:05 AMbob_shaftenkluger says:
I dunno, to me the point of this would be to wear it when I'm NOT doing anything illegal...
Aug 29, 2008. 10:27 PMlilshawn says:
it's not illegal to wear stuff over your face... maybe just a little wierd walking into the bank is all.
Sep 27, 2008. 11:56 AMjdyland says:
Depends on where you are. From West Virginia State code... §61-6-22. Wearing masks, hoods or face coverings... whether in a motor vehicle or otherwise, while wearing any mask, hood or device whereby any portion of the face is so covered as to conceal the identity of the wearer, may: (1) Come into or appear upon any walk, alley, street, road, highway or other thoroughfare dedicated to public use; etc. etc. It goes on and on.
Jul 23, 2009. 7:46 AMmatt ledding says:
Wow. Halloween must be a busy time for the West Virginia State Troopers. They need to toughen up their young offender act.
Oct 20, 2009. 8:01 PMomnibot says:
Fortunately, the innocent have nothing to fear. A phrase which strike terror into the hearts of innocents everywhere ;)
Dec 25, 2009. 2:00 PMbob_shaftenkluger says:
my pants are brown.
(pants, english= underware, american)
Dec 26, 2009. 1:26 PMomnibot says:
Yes, I ones made that mistake in Britain. It was moderately embarrassing. Damn yankee media! ;)
Sep 27, 2008. 11:58 AMjdyland says:
c. Any person who violates any provision of this section is guilty of a misdemeanor, and, upon conviction thereof, shall be fined not more than five hundred dollars or imprisoned in the county jail not more than one year, or both fined and imprisoned.
Sep 2, 2008. 1:55 AMbob_shaftenkluger says:
(Not leet 5peak, broken "s" key!) I know it'5 not, I ju5t meant that I would like to wear it when I'm out doing 5hopping or 5omething, to confu5e the 5ecurity guy5. "I thought what I'd do was, I'd pretend I was one of those deaf-mutes"
Sep 2, 2008. 6:31 PMlilshawn says:
(Not leet 5peak, broken "s" key!) I know it'5 not, I ju5t meant that I would like to wear it when I'm out doing 5hopping or 5omething, to confu5e the 5ecurity guy5. "I thought what I'd do was, I'd pretend I was one of those deaf-mutes # of "5" used - 8 # of "s" used - S sorry - s key works, you just dont use it. oh by the way my 5 key doesn't work so i'm using S instead.
Sep 2, 2008. 11:59 PMbob_shaftenkluger says:
The part in quote5 wa5 cut and pa5ted. And i half lied, the "s" 5witch work5, but ha5 no button on top, 5o i have to jab it with a 5tick. n0W 1f 1 wuz typ3in lik di5, i
Sep 4, 2008. 8:18 PMlilshawn says:
lolz i just bought one for 10 bucks it's silicone and i can rolz it up and "use in the sandstorms great" and "even use under wet waters for short time" i love chinglish
Sep 9, 2008. 6:31 PMwolf555hound says:
z0mg, l1k3 t3h l1v3 fr33 0r d13 h4rd 0n3? (zomg, like the live free or die hard one?)
Sep 11, 2008. 4:39 PMbob_shaftenkluger says:
eh? anyway, sssssssssssssssssss fixed now, yay!
Sep 2, 2008. 6:19 PMC17H19NO3 says:
You lie! your "s" key is working fine! like I told my dad when I was 8 "I cant say fork, I can only say thork!"
Sep 1, 2008. 4:56 AMCaspar says:
Not just weird -- scary. The Chaser team (Australia) had someone who tried to buy things (milk, newspaper...) with a stocking over his head. One shopkeeper offered him money, another locked himself in a back room and called the police. On second thought, don't try it over there. We don't have as many scared people with guns here.
Sep 2, 2008. 1:59 AMbob_shaftenkluger says:
(Not leet 5peak, broken "s" key!) Ha ha, that5 funny! Thought of doing that year5 ago. Didnt.
Dec 2, 2009. 11:20 AMscarabeetle101 says:
 could you make it at least shine at all angles by arranging four or five around a point, almost like a 3d star?
Aug 21, 2009. 5:03 PMugs says:
Their are a few ways to blot yourself out from video cameras. First you need to know what type camera you are being veiwed by. Different type cameras act differently to light sources. Some cameras need no light at all and work from thermal source. These cameras or imagers are difficult to blot out you need to use coolants or heat sources. Other CMOS or Digital Cams like Common IP Cameras are easily affected by counter emissions. A strong IR Diode well placed and worn on ones person will blot your image out, but you must use the proper wavelength Diode and it must be well placed.
I use Sequinyes sequince. The sow on or glue on type in either gold or silver work well but other different colors have their effect too. If the Diode is
placed directly in the middle of the sequince it acts as a reflector to enhance and direct the illumination for the best effectwhich would be your face and other identifying areas. Keep trying you will get it! Also remember it is not exact science either. Different type cameras act differently to different light emissions. thanks!
Jul 19, 2009. 3:40 AMsmessud says:
Sew you IR LEDS to a headband (every 10 degrees or so), so that it does not depend on where your clothes are facing.
Nov 4, 2008. 6:15 PMberky93 says:
this is a cool idea. I, when I need to block a camera's view of something, use my laser. I have a powerful (75mw) and not as powerful (5 mw) green laser, both of which are great for blocking cameras (5 or 75 times better than the red laser in your link, plus more because the human eye is more sensitive to green light than red light)
Jul 16, 2009. 11:23 AMRainbow1946 says:
I am a single 62 yr old woman and needs help. I put 12 cameras in about 8 yrs ago and all 12 was total burned up at different times. my tapes were stolen out of the 3 dvr's, but my house was always lot up. I still having problems with people breaking into my home or stealing everything outside of my home. In June 2009, I put 3 cameras in again. Every time I leave the house my cameras get shut down. example. Sunday went to church. cameras shut down from 9:30am to 12:30. Wed , bible study, I was gone from 6 to 8:30 pm. Came home and put the time in at 5 pm to 8:30 pm and cameras was shut down again from 6:18pm to 8:15pm when they came back on. I have a neighbor that moved next to me in 1994 and that is when my problems started. He was a high officer in securities in the services and he brags that he can shut cameras down and disarmed them. This man and his wife has made my life hell. Do you know any way that I can protect my cameras or is there a way I can prove that he is the one tearing up everything I own. Things are still getting destroyed every day and I don't have any of the on my cameras!!!! email me back and let me know of any suggestions. Thank you.
Jul 19, 2009. 3:30 AMsmessud says:
This is rather strange. First, you have to explain what "shutting down" means. Are they powered by mains, and if so, is the cabling protected all the way? Second, what kind of cameras do you have (just give bbrand and model numbers)? Then how are they connected to VCR (cable, wireless)? Do you have anything recorded on VCR, that is are you sure the VCR is working properly ? Now, considering the harassment, only a police officer can help you. May be you could try concealing a camcorder (on batteries) just to see if there is physical acces to the cameras or if some people are using wireless techniques to disable the electronic inside.
Jun 24, 2009. 6:56 PMinstructors says:
Dont some cameras have to have there night vision setting already on to see the infrared LED's?
Aug 27, 2008. 5:32 AMJouda Mann says:
Fantastic Science on this one. Some people would see this as a failure, but Thomas Edison said of his trials with the Incandescent Lamp: "I didn't fail, I found out two thousand ways how not to make a light bulb". Regardless of whether the experiment yielded the results you wanted, you still know something that you didn't know before, and that is the real point of invention, science, and progress. Also, kudos to you for posting your "failure"
Aug 28, 2008. 8:50 PMtaraist says:
Seconded!
Aug 29, 2008. 4:31 AMJouda Mann says:
Everyone notice that Taraist comes from Texas like I do, and take note that there are some smart people to be found here. I know that the nation has Dubya to thank for No Child Left Behind, but that's not our fault, and we go above the curriculum to actually learn. Hail fellow Texan. Well met!
May 19, 2009. 10:46 PMtruespin1208 says:
tx here too. Hey.....hold my beer and watch this!
Aug 31, 2008. 10:29 PMncaguy says:
A lot of smart people from Texas. Actually Ted Kennedy wrote the No Child Left Behind bill!
Sep 1, 2008. 2:49 PMWolfWoof says:
Yea, Dubya wrote the 'No Child Left a Dime' bill. *dodges flamers*
1-40 of 113next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2351
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
