Why cook a turkey under a can? Well, because...
+ you can avoid heating up your kitchen for hours of turkey cookin'
+ you can avoid burning your house down with a deep fried turkey fire
+ it is a pretty quick way to cook a 12 lb turkey.
+ it is a good, cheap way to feed a large group of people.
+ it is a good way to cook a turkey without access to a kitchen.
+ all the guests you invite over to share your turkey will either say, or think to themselves "this will never work, I hope he has Dominoes Pizza on speed dial."
+ when the turkey comes out golden, tender and delicious, they will all eat their words. Literally!
You will need...
+ a 12 lb turkey, thawed (this can take a few days in the fridge, so get your frozen turkey ahead of time)
+ one stick of butter
+ an injection marinade for turkey and injector (optional). There are several recipes online... google is your friend.
+ a new 5 gallon metal paint can (not plastic)
+ two charcoal chimneys
+ at least 10 lbs of charcoal, more if it is a cold day
+ lighter fluid, if you like big fires, want to scare your wife or children, or just enjoy the madness of a Y-chromosome.
+ newspaper kindling to light the chimneys
+ long handled barbecue grill lighter
+ large size, heavy duty aluminum foil
+ welders gloves
+ barbecue tongs to move the coals around
+ a "stake"
The stake is the only potentially specialized piece of equipment. Mine happens to be a stainless steel "T". The shaft is about 2 feet long, slightly pointed at the end, as it must be pushed or driven into the ground. Welded to the top of the shaft is a two inch cross piece, to help hang the turkey on as it cooks. My uncle made the stake for me in the machine shops where he works, as he gave this kit to me as a gift (packaged in the nice green tub you see to the right in the picture). Anything that provides the same function as described, and will stand up to the cooking heat should work.
Remove these ads by
Signing UpStep 1Prepare the turkey
I think one of the reasons this works so well is that the can forms a low pressure seal with the ground, keeping lots of moisture in with the bird. Also, having the bird up on the rod keeps it from sitting in its juices, which may or may not be important. I think if you can recreate that situation on a grill, it will likely work.
That said, the only way I have ever tried this is as you see in the 'ible (in fact, I will be doing it again in a few days). I would say, try it on the grill and see how it works. But, you might want to try before Turkey day if you have lots of guests on the way...
There are methods for grilling turkey directly, and grilled turkey is very good as well.
Best of luck, and please post your methods and results! Happy Thanksgiving!
Good tip with the oil on newspaper. I am definitely going to try that out.
Putting an apple on the top of the post keeps the bird from slipping down and keeps moisture in the 'oven'.
Otherwise I have cooked turkeys like this under large terra cota pots and it works great...just like the clay pots you use in the oven.
Cheers!
You better believe it's a bad idea! Maybe saggy vinyl siding will become a new landscaping craze...
Thanks for the comment. I have a colleague who does this with chicken as well.
