Introduction: How the Indians Looked for Holes in Their Bicycle Inner Tubes Part I
Sorry, I meant Native Calcuttains. ( spoiler alert: the photo gives it away)
Step 1: This How I Find Illusive Tube Holes
Step #2 fill the tube with air (I use a pump)
Step #3 if step #2 fails, you have a leak.
Step #4 if step #2 succeeds you could still have a leak.
Step #5 hold sections of the tube under water in the toilet tank.
It is fast easy and has even worked in tanks with floats
the last 6 lines are of use to some
I know, I have had more hole in my tubes than I could lift.
first look at the tire feel the inside for sharp things warning: SHARP THINGS .
I use a small knife and scrape and pull them out -use the distance from the valve to look for the hole
if you can't pump fast enough, stop and look for the hole . or twist the tube into an "8"and clamp down so you're blocking the air from part of the tube then let the "compressed air " whoosh out and find the hole
