How To: Make a Simple Crystal Radio
78,098
37
28
Posted in TechnologyElectronics
Introduction: How To: Make a Simple Crystal Radio
About: I'm a proud kiwi, and I have many kiwi traits. Us kiwis, we're modest, you wont catch one of us skiting about our achievements for years. We have our ingenuity, how many great inventions come from (way) do...
I know there is many on this topc but this is slightly different. Instead of using magnet wire, gelana, iron pyrite, germanium diodes, I have used a rusty knife blade (A craft knife with the snap of blades) and a pencil lead as a detector, a crystal Earphone as an earphone, Solid Cat 6 wire as the winding wire for the coil, hookup wire as an aerial and earth. Hope this shows you that you really can use anything to make this work. Im sorry for the lack of pictures in constuction (Im doing this in retrospective to start with)
Step 1: Matarials
This may end up as a running list as I improve/modify the radio.
For the Coil:
4 meters solid core Cat. 6 wire (4 twisted pairs)
3" OD PVC pipe
For the Cat's Whisker Detector:
1 old rust craft blade
1 HB (expierement) pencil
Hook-Up wire
1 paperclip
Small Piece of wood (to mount on)
3 wood screws (preferably cap but if you want to use counter sunk then you need custom metal washers too.)
Misc Electrical:
LOTS of hook-up wire (I bought 25 meters and turned out that was only just enough)
Variable Capacitor (Mine was 60pf - 160pf)
Crystal Earphone (normal MP3 headphones won't work apparently but feel free to try them out)
Germanium Diode (for testing although not necessary)
Aligator Clips
Tools I used:
Hammer
Nail
Cordless Screwdriver
Number 8 wire (I think in america it might be called fencing wire otherwise google it)
My Sisters electronic board (I needed a Germanium Diode and a tuning capacitor. I no longer need the Germanium Diode and im buying a variable capacitor)
Soldering Iron
Solder (I guess you could call it a tool. Maybe if you considder it as an adhesive)
Automatic Wire Stripper (This is AMAZING!! If you dont have one then you need it. I strips wires and can cut them to. Saves me hours!!)
Step 2: Winding the Coil
This was VERY tedious. I recommend listening to the radio while doing this. After buying 4 meters of the Cat 6 wire I have to 'open it up' there were 4 twisted pairs and a plastic seperator thingy. After spending TOO much time unwinding the first pair, I convinced my sister to help. Im not sure how but she did another 2 in half the time it took me to do one. I wasn't watching her do it so I cant suggest how to do it faster. Onto the coil itself.
Step1: Drill 2 small holes (about 7mm apart) near one end (make sure the are following a winding pattern).
Step 2: Thread a small piece of the solid core wire into th two holes (push it through the Outside then back through to the outside from the center (sorry if this confuses you.)
Step 3: Start to wind the wire round up until you have 10 turns. Then you make a tap in the coil (make a loop then twist it together). Do this on the 16th, 24th, 32nd, 40th, 52nd, and 65th turns. Next continue to wind the coil untill you get to 80. Now drill two more holes as close as posible to the end of the coil and thread the end through. Thank God you have finished. You can also tape to hold the coil as you go.
Step 4: On the taps you have made you need to get the insulation off the twist them tightly. When you have 8 taps all nice and coppery you can tin the with solder.
Step 3: Cats Whisker Detector
The was called the cats whisker detector because in the original 'Crystal' radios the has a tiny metal (not always copper) touching a semi conducting mineral. This small wire was similar to a cats whisker. Im sure there is other kinds of detectors out there but I couldnt find them.
Step 1: Take the HB pencil (2B, 2H, or whatever else shoud work) and using a knife cut away the wood so you can get a piece of lead (mine would be about 1 1/4" long). Now using a knife, sharpn the pencil lead to a small point (im sure the smaller the better)
Step 2: Take a piece of copper wire (about 6 - 10" long) and strip all of the insulation off. Use this to bind the pencil lead to the paper clip (unbend it obviously). Now solder over the wire and you should get a nice strong joint (but dont test it to much. If you break the lead you may need to start over!
Step 3: Screw a small wood screw into the board (leave a little sticking up)
Step 4: Heat up the screw with a soldering iron and make a small pool of solder into it. Tin a small piece of hook-up wire and melt it onto the screw. Do the same thing with the paper clip (the non pencil end)
Step 5: Bend the paper clip out of the way and some how screw the rusty knife blade to the wood. On one of the screws you need to solder another wire onto it.
Step 6: Bend the paper clip to look similar to the one in either of the pictures (there needs to be a little bit of force onto the blade.
Step 4: Aerial and Earth
For the aerial you need it to be as high as possible and as long as possible. I had mine loop around the roof of the garage and then leading to my room. DO NOT let the end of the wire touch ANYTHING that may ground it. On mine I folded over and end and covered it with electrical tape (ask if you want a picture). For the earth a coper cold water pipe may be used. DO NOT use a gas pipe. Also, all houses SHOUD have an AC earth (in NZ anyway) and you could also use that. If all else fails just get a long (minimum of a meter/yard) piece of metal pipe/wire and force it into the ground.
Step 5: Wireing It Together and Tuning
At the end of this step we will end up with a working radio.
Step 1: Take the variable capacitor and snip on little tab off (if you have three) DO NOT CUT THE CENTER TAB!! If you do that then I WILL NOT work. Snip either the right or the left. you want the capacitance to go up as you turn it to the left.
Step 2: At the start of the coil attach the aerial with aligator clips (you may solder this on later when you know it works.)
Step 3: Attach one of the capacitor leads to the start of the coil and aerial.
Step 4: Attach the other side of the capacitor to the earth and the selector (selector comming soon. You may just use an aligator clip as the selector for now).
Step 5: Attach one lead from the earphone to the earth and the other to the wire connected to the knife blade on the detector.
Step 6: Attach the other lead from the Whisker Detector to the end of the coil.
Step 7: Attach the germanium diode in parallel with the detector and turn the capacitor until you can hear (even if faintly) a station. Un wire the germanium diode.
Step 8: Now move the pencil around till you can hear the station again (you ahve found a 'hot spot' and try to tune it so it is more audable.
Step 9: Continue to fiddle around with your radio and most of all HAVE FUN!!
    • Space Challenge
      Space Challenge
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    28 Comments
    what happens if the diode is moved to a different tap? Can someone answer where the mutual inductance element goes?
    I like the design, its nice an simple.
    I need your honest opinion though, I wish to build a condensed version for a project of mine. I was wondering how well this radio worked. I mean, is it something you would listen to with headphones?
    thanks.
    It’s very useful article thanks for the sharing the good and informative information .Thank u….
    Fence Company
    A fast and easy way to untwist CAT5, CAT6, etc. wire is to tie one end of the twisted pair to something solid and put the other end in a drill chuck. Keep the wire tight as you run the drill and in no time at all you'll have the individual wires separated.
    Gene
    Your schematic is way too complex for a foxhole radio. You've already constructed about all you need for it. A 120 wind coil and a razorblade/pencil diode. Adjusting the position of the pencil lead is how the unit is tuned. That along with a sensitive enough earphone, a good ground (water pipe) and arial and you're ready. The radio you've drawn is a crystal set, but wouldn't qualify as a "Foxhole radio" since it requires parts that a solder wouldn't have had in the field.
    i bet if i was in a foxhole a pencil could just wright a not an a simple few folds i could fly it to the guy next to me an so forth passing the note over quicker that shakeing hands could build any of that in hope the main radio guy was lissening an if so didnt think i was the enimey try a fast on then ordering a bombing onto me lol ~the british are comeing the british are come say do u have extra news print ive to poop now ~
    Foxhole radios allowed soldiers to keep up on news about the progress of the war. I read an article about POW's in German camps listening to the BBC to get news. Such news was a counter measure to propaganda prison camp officials might want to use to control the morale and thoughts of the prisoners. Even the German guards were not getting reliable news about where the front was and how close the Russians were. Although guards were to confiscate contraband, like radios, one guard knew about the prisoner's radio and sought out the prisoners to get good information he could not get elsewhere. When the prisoners went out on work details they stole telephone receivers and bicycle generators to get wire for radio coils. They picked up chunks of coal slag from furnaces that had been used on roads like gravel and made radio detectors from sensitive points on the slag pieces. At night power was cut to the barracks and soldier connected their radios to the electrical system to use its wire for an antenna. Many of the prisoners had experimented with crystal radios as boys before the war.
    I don't think you understand the concept of a foxhole radio at all. It is a receiving device, and the soldiers would use it to listen to the news about the war. With a fox hole radio, soldiers could listen to victories from other units, tragedy back in England, or even just listen to music. Morale was a very important thing to keep high in the war.
    The pencil "lead" isn't what tunes the radio, it's what detects (demodulates) the audio out of the RF signal. The coil and capacitor make up a tuned circuit which when adjusted (amount of plate meshing and coil tap positions) tunes in the desired station. You can make a capacitor by using a couple foiled gum wrappers (or some foil and paper) and rolling your own, making sure the two foil "plates" don't contact each other to short it out.
    So all your saying is if I remove the capacitor then I could call it a fox hole radio?? A lot of the soldiers pulled apart motors and radio gear to get the headphones and winding wire. Maybe the soldier got the variable cap out of the radio?? This coild is an 80 wind coil. I dont know how you can get different stations witht eh pencil though.
    Yes. Remove the capacitor and the switch. Yes. Soldiers built all sorts of radios using all sorts of parts, but the device that became known as the Foxhole Radio was build with what they had on hand and didn't include any components other than the unusual crystal made up of the pencil and razer blade. They were "Blue Blades" at the time, made from galvanized steel. It was tuned by moving the lead around to find just the right spot on the blade that filtered a station through.
    Here is a good example of a Foxhole Radio.
    O yes I see. I have changed the name to a simple crystl radio. Thanks for pointing it out :D
    I would have liked to see you complete the Foxhole Radio! You were well on your way. All you need are a few more windings and a 300 ohm earphone. I'm sure that knife blade would work well.
    Im thinking of makeing many more adios so that could b on the list. I dont have tubes but apparently you can make them
    i have c quick question, can i use a normal speaker instead of the crystal ear phone? thanks
    I see you did not get an answer to your question. A crystal radio has no added source of power--only the energy in the broadcast signal. A normal speaker requires additional power from an amplifier with an added power source, like a battery or power from a wall socket. An earpiece needs much less power than a normal speaker and can make enough sound to be barely heard. Some circuits use a crystal radio circuit to detect and tune the signal. Then they add a small amplifier circuit to drive a normal speaker.
    Where could I get a crystal earphone without buying one. Is there anything I can take one out of? Would an old telephone headset work?
    What country are you from? Most earphones/headphones dont use crystals ear pieces anymore.
