3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to: Make a simple Crystal Radio
I know there is many on this topc but this is slightly different. Instead of using magnet wire, gelana, iron pyrite, germanium diodes, I have used a rusty knife blade (A craft knife with the snap of blades) and a pencil lead as a detector, a crystal Earphone as an earphone, Solid Cat 6 wire as the winding wire for the coil, hookup wire as an aerial and earth. Hope this shows you that you really can use anything to make this work. Im sorry for the lack of pictures in constuction (Im doing this in retrospective to start with)
Step 1Matarials
Matarials
This may end up as a running list as I improve/modify the radio.
For the Coil:
4 meters solid core Cat. 6 wire (4 twisted pairs)
3" OD PVC pipe
For the Cat's Whisker Detector:
1 old rust craft blade
1 HB (expierement) pencil
Hook-Up wire
1 paperclip
Small Piece of wood (to mount on)
3 wood screws (preferably cap but if you want to use counter sunk then you need custom metal washers too.)
Misc Electrical:
LOTS of hook-up wire (I bought 25 meters and turned out that was only just enough)
Variable Capacitor (Mine was 60pf - 160pf)
Crystal Earphone (normal MP3 headphones won't work apparently but feel free to try them out)
Germanium Diode (for testing although not necessary)
Aligator Clips
Tools I used:
Hammer
Nail
Cordless Screwdriver
Number 8 wire (I think in america it might be called fencing wire otherwise google it)
My Sisters electronic board (I needed a Germanium Diode and a tuning capacitor. I no longer need the Germanium Diode and im buying a variable capacitor)
Soldering Iron
Solder (I guess you could call it a tool. Maybe if you considder it as an adhesive)
Automatic Wire Stripper (This is AMAZING!! If you dont have one then you need it. I strips wires and can cut them to. Saves me hours!!)
25 comments
Dec 12, 2011. 9:40 PMsonamsnv says:
It’s very useful article thanks for the sharing the good and informative information .Thank u….
Fence Company
Sep 29, 2011. 7:21 PMmoparman says:
A fast and easy way to untwist CAT5, CAT6, etc. wire is to tie one end of the twisted pair to something solid and put the other end in a drill chuck. Keep the wire tight as you run the drill and in no time at all you'll have the individual wires separated.
Gene
Sep 16, 2007. 4:50 PMLasVegas says:
Your schematic is way too complex for a foxhole radio. You've already constructed about all you need for it. A 120 wind coil and a razorblade/pencil diode. Adjusting the position of the pencil lead is how the unit is tuned. That along with a sensitive enough earphone, a good ground (water pipe) and arial and you're ready. The radio you've drawn is a crystal set, but wouldn't qualify as a "Foxhole radio" since it requires parts that a solder wouldn't have had in the field.
Jul 17, 2010. 6:57 PMriverreaper says:
i bet if i was in a foxhole a pencil could just wright a not an a simple few folds i could fly it to the guy next to me an so forth passing the note over quicker that shakeing hands could build any of that in hope the main radio guy was lissening an if so didnt think i was the enimey try a fast on then ordering a bombing onto me lol ~the british are comeing the british are come say do u have extra news print ive to poop now ~
Nov 24, 2010. 5:26 AMPhil B says:
Foxhole radios allowed soldiers to keep up on news about the progress of the war. I read an article about POW's in German camps listening to the BBC to get news. Such news was a counter measure to propaganda prison camp officials might want to use to control the morale and thoughts of the prisoners. Even the German guards were not getting reliable news about where the front was and how close the Russians were. Although guards were to confiscate contraband, like radios, one guard knew about the prisoner's radio and sought out the prisoners to get good information he could not get elsewhere. When the prisoners went out on work details they stole telephone receivers and bicycle generators to get wire for radio coils. They picked up chunks of coal slag from furnaces that had been used on roads like gravel and made radio detectors from sensitive points on the slag pieces. At night power was cut to the barracks and soldier connected their radios to the electrical system to use its wire for an antenna. Many of the prisoners had experimented with crystal radios as boys before the war.
Mar 19, 2008. 10:34 AMn0ukf says:
The pencil "lead" isn't what tunes the radio, it's what detects (demodulates) the audio out of the RF signal. The coil and capacitor make up a tuned circuit which when adjusted (amount of plate meshing and coil tap positions) tunes in the desired station. You can make a capacitor by using a couple foiled gum wrappers (or some foil and paper) and rolling your own, making sure the two foil "plates" don't contact each other to short it out.
Sep 17, 2007. 9:27 AMLasVegas says:
Yes. Remove the capacitor and the switch. Yes. Soldiers built all sorts of radios using all sorts of parts, but the device that became known as the Foxhole Radio was build with what they had on hand and didn't include any components other than the unusual crystal made up of the pencil and razer blade. They were "Blue Blades" at the time, made from galvanized steel. It was tuned by moving the lead around to find just the right spot on the blade that filtered a station through.
Here is a good example of a Foxhole Radio.
Sep 17, 2007. 12:42 PMLasVegas says:
I would have liked to see you complete the Foxhole Radio! You were well on your way. All you need are a few more windings and a 300 ohm earphone. I'm sure that knife blade would work well.
Oct 28, 2010. 5:03 PMthe "wow shammy" says:
i have c quick question, can i use a normal speaker instead of the crystal ear phone? thanks
Nov 24, 2010. 5:15 AMPhil B says:
I see you did not get an answer to your question. A crystal radio has no added source of power--only the energy in the broadcast signal. A normal speaker requires additional power from an amplifier with an added power source, like a battery or power from a wall socket. An earpiece needs much less power than a normal speaker and can make enough sound to be barely heard. Some circuits use a crystal radio circuit to detect and tune the signal. Then they add a small amplifier circuit to drive a normal speaker.
Apr 14, 2009. 2:45 AMFeedTheGrid says:
Very cool.
Nov 1, 2008. 4:33 PMXellers says:
Where could I get a crystal earphone without buying one. Is there anything I can take one out of? Would an old telephone headset work?
Nov 2, 2008. 6:16 AMXellers says:
My base is in the US of A right now. But I do have access to some very nice "old stuff" that isn't really antique, but is more like '70s and '80s era.
Nov 3, 2008. 4:03 PMXellers says:
I just dug up this old telephone that has a spinning dial. Do you think that the headset from that would work? I can just unplug it from the main unit, and put a new cable into it as not to harm it.
Nov 16, 2008. 7:15 AMXellers says:
I took apart the telephone and found out that it was in fact a peizo. Unfortunately, it wasn't sensitive enough for me because I couldn't pick anything up with the radio I built. I simply can't put up a hundred foot antenna... I'll have to wait to get a super high impedance crystal earbud...
Nov 20, 2008. 4:45 PMsousa says:
Hello, I think you don't have to wait any more. Just mesure de piezo resistance and manage one resistor that, connected in parallel to the piezo, give out one resistance of about 2k ohms. I use 1Meg resitor and it works. Or else get one audio tranformer (impedance tranformer) and connect the your radio to the primary(about 2k ohms) and the piezo to the secondary(about 15k ohms). You can also use an ordinary 9v-220v transformer. It works, but it's not so efficient as the audio T. Note that some piezo's have a circuit to drive them. If you have one of those, discard the driving circuit. Hope it helps. Regards
Nov 10, 2008. 1:08 PMdciocoiu says:
I have that 130 in 1 kit too!
Nov 3, 2008. 4:05 PMXellers says:
Can you post a photograph of the completed project so that I can see the variable cap. too?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:microman171
I'm a proud kiwi, and I have many kiwi traits. Us kiwis, we're modest, you wont catch one of us skiting about our achievements for years. We have our ingenuity, how many great inventions come from (...
more »
